Pocket GPS World :: View topic - BTBrowserEnabled
BTBrowserEnabled
tom9851
PostPosted: Sat Jul 23, 2005 3:59 pm    Post subject: BTBrowserEnabled Reply with quote
I understand that to stop the blueooth manager on my H2210 constantly popping up as soon as I load TTN3 I have to set "BTBrowserEnabled" to Zero (whatever that means!).
Can some kindly soul tell me how to do this - in simple step-by-step instructions please as I am not a tech-head like many on these forums!
Thanks in advanTom
___________
IPAQ2210/ROM-1.10/LEXAR 32X 256MB SD/Kingston ElitePro 1GB CF
TTN3-V3.03/Wired GPS-V3.03/Globalsat BT-338
tom9851
PostPosted: Sat Jul 23, 2005 3:59 pm    Post subject: Reply with quote
I mean...
Thanks in advance
Tom
___________
tom9851
PostPosted: Sat Jul 23, 2005 4:01 pm    Post subject: Reply with quote
Oh and by the way... should I be using V3.07 instead of V3.03?
Tom
___________
Jonc
PostPosted: Sat Jul 23, 2005 5:44 pm    Post subject: Reply with quote
This worked on my Dell axim today
Download this http://www2r.biglobe.ne.jp/~tascal/download/pocketpc/tre_e.htm
Then look here
http://pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=3586
John
tom9851
PostPosted: Sat Jul 23, 2005 6:14 pm    Post subject: Reply with quote
I downloaded tre090p as you suggested - it's now on my PPC but when I tap on it I get "there is no application associated with "tre090p". Run the appliation first, then open this file from within the application"
What have I done wrong?
Tom
___________
tom9851
PostPosted: Sat Jul 23, 2005 6:52 pm    Post subject: Reply with quote
I have just had a look at previous posts on this subject and have downloaded BtRegTweak which seems to be for idiots like me! Seems to have done the trick - thanks.
I noticed that when I was using my TomTom wired gps I could straight into TTN3 or PostCodes and either browse the map or look for a postcode without any need for a connection to the gps. I notice that since I have started using the Globalsat BT-338 I cannot do this without first starting bluetooth on the H2210 and starting the GPS - is this normal?
Tom
___________
Jonc
PostPosted: Sat Jul 23, 2005 7:40 pm    Post subject: Reply with quote
New to this myself and not sure if Dell Axim and your PPC should use the same program.
If you click start>Programs do you have an Icon with the name TRE below it.
John
Jonc
PostPosted: Sat Jul 23, 2005 7:47 pm    Post subject: Reply with quote
Forget my reply to your post above.
You should be able to look at maps etc without connecting the reciever via bluetooth
John
tom9851
PostPosted: Sat Jul 23, 2005 8:15 pm    Post subject: Reply with quote
Well as soon as I tap on the TomTom Navigator link on my H2210 screen the Bluetooth Browser comes up. Same if I go to PostCodes - which of course has to load the TTN maps in order to locate the postcode and that obviously tries to load TTN3 so same thing happens - loads up Bluetooth Browser - bit of a pain if all I want is to browse the map etc.
Tom
___________
tom9851
PostPosted: Sat Jul 23, 2005 8:34 pm    Post subject: Reply with quote
My fault! I failed to do a soft reset after using tje BTRegTweak prog and setting it to Automatic (Background) mode - now allows me to load TTN3 and/or PostCodes without bringing up Bluetooth Browser.
All seems to be working now - think I will leave well alone and stop finding new problems!
Tom
P.S. One of these days I will find the courage to load the TTN5 upgrade - but maybe that's for another day!
___________
Jonc
PostPosted: Sat Jul 23, 2005 9:10 pm    Post subject: Reply with quote
From what I hear TT5 is best avoided at this time, I use TT3 in London for deliveries and it works well so I do not see the need to upgrade.
John
tom9851
PostPosted: Sat Jul 23, 2005 10:33 pm    Post subject: Reply with quote
Yes I too use TTN3/PostCodes in my work (HGV driver) and to tell you the truth I really cannot take the risk of replacing what is a pretty stable and reliable aid (though far from perfect) for something that appears , at least that is the conclusion I have reached from reading the many many posts about TTN5 problems, to be saddled with too many bugs to be an effective (at least as far as I am concerned) replacement for TTN3. I would have been more than satisfied to have seen TTN5 as TTN3 with uptodate maps and full postcode navigation on par with Niels's PostCode - with no other changes. Sadly this doesn't appear to be the case.
Tom
___________
22.055 (29 May 24)
