Pocket GPS World :: View topic - TTM5 - Losing signal
Dansco
PostPosted: Fri Jul 22, 2005 9:40 pm    Post subject: TTM5 - Losing signal Reply with quote
Well I recently bought a PBT-111 GPS unit on ebay and was having problems getting a fix. I was told it might take a while so after several attempts I took it to cricket yesterday and it actually WORKED...
Great but it soon crashed (Tom Tom on my Nokia 6260 that is) when we were leaving to go home and now I can't get a fix again.
My question is that if you make a first "fix" it should then be quick to pick up again right Question
Has it lost it's fix coz of the crash or does the unit not save it Confused
TIA Dan Wink
Polstar GPS - http://www.polstargps.com/products/pbt-111.htm
Dansco
PostPosted: Sat Jul 23, 2005 11:29 pm    Post subject: Reply with quote
30 odd looks but not one reply...
Surely someone knows Question
markyhedgehog73
PostPosted: Sun Jul 24, 2005 12:27 am    Post subject: Reply with quote
Hi there
for all gps receivers there is a time for first fix after initial startup of the receiver
1 is a cold start
2 is a warm start and
3 is a hot start this is dependant on whether or not you turned the receiver off 10 secs ago or ten mins ago
as for the crashing of tt i cannot see this being down to your receiver but more likely just a glitch in your setup maybe Confused
Dansco
PostPosted: Sun Jul 24, 2005 2:03 pm    Post subject: Reply with quote
markyhedgehog73 wrote:
Hi there
1 is a cold start
Well I had the cold start (first fix) then I think it was a warm start when it crashed. Now I seem to have to do a first fix again Confused
I thought once you have done the first fix it saves it Question
markyhedgehog73
PostPosted: Sun Jul 24, 2005 4:03 pm    Post subject: Reply with quote
tt does load up quicker after the initial setup of the application but if your chipset in the receiver is of a lower quality then time to first fix will always be slow especially on a cold start i have known it take up to 20mins with some receivers Confused
have you got tt up and running again without connection to the receiver?
also if its possible for you, could you leave the receiver on in your vehicle so its always on and then when you run tt it will make the connection as and when?
Dansco
PostPosted: Sun Jul 24, 2005 5:13 pm    Post subject: Reply with quote
I've recently had to format my phone so Tom Tom has been removed and reinstalled.
I did run TT5 before I uninstalled it so it works but lost the fix. That took me about 10 mins in a field (in the middle of nowhere).
I will run TT5 again tomorrow and let you know. Thanx for the help Wink
