Pocket GPS World :: View topic - formatting a memory card on your pc
aliendad
PostPosted: Fri Jul 15, 2005 9:48 am    Post subject: formatting a memory card on your pc Reply with quote
i think i saw recently that someone said there memory card was corrupt?
this may help, if you format using windows xp or similar the default format is "fat32", i dont know about all phones but the 6600 cannot read "fat32" so it will say the card is corrupt.
if you do format a card using a pc, before starting the format, change the fat32 to fat on its drop down menu, this should then make the card readable by the phone.
also if you format the card on the phone, although it will take much longer, it will create sub directories for video/music/pictures
hope this is of some help to someone out there?
Getssmart
PostPosted: Fri Jul 22, 2005 10:02 am    Post subject: Re: formatting a memory card on your pc Reply with quote
aliendad wrote:
....also if you format the card on the phone, although it will take much longer, it will create sub directories for video/music/pictures....
Do you know what the procedure is for 'formatting on the phone' on a C500?
I hate technology !....or is it technology that hates me?
aliendad
PostPosted: Fri Jul 22, 2005 12:15 pm    Post subject: Reply with quote
can't help on that one, I have a nokia 6600 myself.
awarner
PostPosted: Fri Jul 22, 2005 2:13 pm    Post subject: Reply with quote
Best way to format your card is to use Task Manager from www.binarys.com
Life's too fast can I get off and walk for a bit?
Microsoft MVP Mobile Devices
MoDaCo.com Staff Team Leader
westentertainer
PostPosted: Thu Aug 18, 2005 12:12 am    Post subject: Reply with quote
how do you format a card for spv e200 any ideas my phone does not recognise the card any thoughts
awarner
PostPosted: Thu Aug 18, 2005 8:45 am    Post subject: Reply with quote
Try another card, depending on the make the card may be dual layer which is not compatable with the E200.
Cards by Sandisk are normally ok to use.
westentertainer
PostPosted: Thu Aug 18, 2005 3:46 pm    Post subject: Reply with quote
no the card did work in the phone until itried to download 5
awarner
PostPosted: Thu Aug 18, 2005 10:09 pm    Post subject: Reply with quote
Strange that does not make sense Confused
As for formatting your card use the app I mention above, it will format the card to the correct type for the phone.
westentertainer
PostPosted: Fri Aug 19, 2005 1:10 am    Post subject: Reply with quote
its on fat at the moment realy baffled
awarner
PostPosted: Fri Aug 19, 2005 10:14 am    Post subject: Reply with quote
Back to basics,
What is the make and size of the card and also
more importantly do any cards now work in your phone?
awarner
PostPosted: Fri Aug 19, 2005 10:26 am    Post subject: Reply with quote
What happens when you insert the card in the phone while it is powered on.
westentertainer
PostPosted: Fri Aug 19, 2005 1:28 pm    Post subject: Reply with quote
nothing ,it all started when i tried to copy over tt5 in card reader ,it was alright before this if i put another card in with dvd films on its ok
awarner
PostPosted: Fri Aug 19, 2005 7:13 pm    Post subject: Reply with quote
The only other thing I can suggest if you can not format with a card reader etc is to send me the card inc return postage and I will have a go a formatting it for you. I can also test the card in other Smartphones.
If you are interested pm me.
aliendad
PostPosted: Fri Aug 19, 2005 8:46 pm    Post subject: Reply with quote
did you just remove the card when yuo thought everything had finished,
or did you use the "safe to remove" icon?
westentertainer
PostPosted: Fri Aug 19, 2005 10:28 pm    Post subject: Reply with quote
what hapend was i tried to copy over tt5 in card reader but the card reader said something about violation and the card reader would not operate so i had to reeboot pc,,,the funy thing is though when i active sink the e200 and go into card tt is there but it will not show up in phone
