bigal2003 Occasional Visitor
Posted: Thu Jul 14, 2005 9:21 am Post subject: syson gps cf plus with tommtom 5 |
hi al
i need your help, i,ve just upgraded to tomtom 5 which at the moment looks good but i have a problem, its says all the time no gps device. i,ve tried to change it to all of the different devices listed but it dos'nt seem to cover my gps receiver......can you help i need it to work this weekend!!! |
cisco43 Occasional Visitor
Posted: Fri Jul 15, 2005 2:37 am Post subject: |
I'm in the same boat.
Any one managed to get it working??? |
Darien Occasional Visitor
Posted: Thu Jul 21, 2005 11:37 pm Post subject: |
Here is the answer you need, it seems mad but only way to get to work.
Select "Change preferences"
Select Preferences 4 of 6
Tap "Show GPS Status"
Tap "Configure"
Here is the odd part
Select "Other Cable NMEA GPS"
GPS baud rate = 4800
Done
Now select your Bluetooth Serial Port.
Good luck and happy nav'ing
Darien |
countyboy239 Occasional Visitor
Posted: Fri Jul 22, 2005 9:19 am Post subject: |
I have tried that and doesnt seem to work for me,,,It seems logical to click on syson chip,,,Syson chip is picking up satellites but tom tom saying "no gps device"...Can anyone help, I have tried lots of combinations,,,,!! ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
frolicuk Occasional Visitor
Posted: Sat Jul 30, 2005 3:13 pm Post subject: similar problem |
I also cannot seem to get the dam thing to link up.
My combination is
HP HX 4700
Sysonchip GPS CF Plus
Navigator 5 |
Posted: Sun Jul 31, 2005 7:15 pm Post subject: |
tried the patch and variations on setting the syson cf card up on different com ports no luck.
Update from TT is installed.
any more ideas. |
SjB Occasional Visitor
Posted: Wed Aug 10, 2005 8:28 pm Post subject: |
I use a SysOnChip CF 256 antenna with my iPAQ 2210. I have recently upgraded from TT3 to TT5 and having used the 'other NMEA' and 4800 baud settings during the upgrade have had no problems.
"No GPS device' appears on first starting TT5 (even though the SysOnChip is clearly showing a fix with a solid, non-flashing, LED but disappears after ten seconds or so.
Feel free to ask me to check anything else such as precise version numbers of anything if you wish. |
kjnpbr Occasional Visitor
Posted: Wed Aug 10, 2005 11:18 pm Post subject: |
I've had absolutely no problems with my SysonChip CFPlus. What I think your problem might be is that your GPS device may be in SIRF mode, I don't think Nav5 is SIRF compatible. If you have your SysonChip driver disc, it has instructions in powerpoint format on how to change from SIRF to NMEA. Then you can use the method above to set your tomtom up. |
