alex_0904 Occasional Visitor
Posted: Sat Jul 16, 2005 10:55 am Post subject: Where will the voice come from? |
hi there.
If i buy one of these bluetooth hands free units for my nokia 6630 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=6414988017, will the ttm5 voice instructions still come out of the phone speaker or will they automatically go through this?
Many Thanks! |
Roberto Occasional Visitor
Posted: Sat Jul 16, 2005 3:45 pm Post subject: |
Not sure if the 6630 supports more than one Bluetooth paired device at a time. If it doesn't you will not be able to use a BT headset and your BT GPS at the same time |
Posted: Sat Jul 16, 2005 6:16 pm Post subject: |
Roberto wrote: | Not sure if the 6630 supports more than one Bluetooth paired device at a time. If it doesn't you will not be able to use a BT headset and your BT GPS at the same time |
ah yes thats true it doesnt, however i have heard there's a programme that will allow you to do it. anyone know where to find it? |
Posted: Sun Jul 17, 2005 3:21 pm Post subject: |
does no one know the answer to my question? |
dhevans_6 Regular Visitor
coolice Occasional Visitor
Posted: Sun Jul 17, 2005 9:06 pm Post subject: |
Hey,
The 6630 does support two bluetooth connections at once. In this case a serial connection to the GPS receiver & an audio connection the the GPS.
What you do is pair both units in the Bluetooth menu as normal & select both to authorised, so connections take place automatically as the headset or GPS is turned on & in range of the phone.
Then what I do is turn on the headset first & allow it to pair up to the 6630, signalled by a beep in the headset.
Now turn on the GPS unit & allow it to warm up & acquire the satellites. Open TomTom & voila the GPS should be recognised, or may need pairing through TomTom if it's the first time it being used.
On my 6630 it works this way, I was worried it wouldn't and have a small app allowing two BT connections but it's not needed.
Ian |
wayneywoo Occasional Visitor
Posted: Fri Jul 22, 2005 7:27 pm Post subject: |
I've got a Nokia CK-7W bluetooth carkit along with a Holux GPSlim236 Bluetooth receiver.
Get in car and start her up. Phone automatically pairs with car kit. Then turn receiver on and within a short moment, Tom Tom has paired with the receiver.
I've tried this in a number of ways and each time the phone automatically pairs with both the Bluetooth carkit and receiver.
Just manually pair them first and authorise them to make connections automatically.
Should work.
Regards
Wayne |
laich71 Occasional Visitor
Posted: Tue Jul 26, 2005 7:09 pm Post subject: |
i found that using bluetooth and nokia 7710 the speaker is activated only if phone generates sound and then after a while goes off (probably to save battery). as a result i was missing the first bit of the instruction as there is a delay.
I use nokia HF-3 wired handsfree and managed to tuck away the wire quite neatly and this much better. |
