Pocket GPS World :: View topic - 5.2 upgrade not working HELP !!!!
sparkey-b
PostPosted: Mon Jul 11, 2005 1:55 pm    Post subject: 5.2 upgrade not working HELP !!!! Reply with quote
I have a TTG on v4.420 with the originally supplied SD card - all was working fine. I downloaded the 5.2 upgrade (ttgroup520.exe) from the TomTom website and followed the instructions to the letter. Initially it complained that there was not enough space on the SD card so I removed some of the voice prompts with the upgrade software then proceeded to upgrade - which according to the screen says that the upgrade was successful.
However - upon removing the USB cable and turning the TTG on all I get is an animated screen showing the SD card removed from the unit with a big red cross over the card.
Am I doing something wrong ???
By the way - if I remove all the files from the SD card and then resore my original files (from backup) the unit works fine again.
HELP !!! Confused
PostPosted: Mon Jul 11, 2005 3:23 pm    Post subject: Reply with quote
any chance you can try this with a bigger card?
sparkey-b
PostPosted: Mon Jul 11, 2005 4:50 pm    Post subject: Reply with quote
I dont have a bigger card at this time - what size would you reccomend ??
I will be upgrading to the newest UK maps etc. once Ive got 5.2 working so I guess I'll need one anyway.
Thanks in advance
PostPosted: Mon Jul 11, 2005 6:57 pm    Post subject: Reply with quote
as big as you can afford. Nowadays 1GB seems to be a good starting size.
And don't think it will last forever - it's amazing how quickly even a 1GB card can fill up ...
HOG
PostPosted: Tue Jul 12, 2005 12:12 pm    Post subject: Reply with quote
Also if you have a TTG and not a 300 or 500 I would not bother installing the 5.2 upgrade at all as this is meant primarily for the 300 & 500 models.
Install the 5.1 and you should be OK. I agree about the card size too, I have a 1GB card in my TTG.
sparkey-b
PostPosted: Tue Jul 12, 2005 9:19 pm    Post subject: Reply with quote
Anyone out there have a copy of the 5.1 install .exe file they could send me ???
I have trawled the net and can only find the 5.2 version
Your help would be much appreciated.
Regards
Sparkey-b
danman
PostPosted: Tue Jul 12, 2005 9:27 pm    Post subject: Reply with quote
Hi Sparkey-b,
If you post your email address I will forward V5.1 install file.
Cheers,
danman
sparkey-b
PostPosted: Tue Jul 12, 2005 9:43 pm    Post subject: Reply with quote
cgbright@bulldoghome.com
Many thanks
Or download it from http://myweb.tiscali.co.uk/oldboy/TomTomUpdates/ttgoupg510.exe
sparkey-b
PostPosted: Tue Jul 12, 2005 10:04 pm    Post subject: Reply with quote
You are a star - 5.1 installed perfectly on my TTG - THANK YOU
all I need to do now is get a bigger card and the new maps and postcode files
Regards
Sparkey-b
:D :D :D :D :D :D :D :D :D :D :D
22.062 (12 Jun 24)
