Pocket GPS World :: View topic - iPAQ Hx4700 + Globalsat BT 338 +TTN5
mobile
PostPosted: Tue Jul 12, 2005 3:28 pm    Post subject: iPAQ Hx4700 + Globalsat BT 338 +TTN5 Reply with quote
The forum has been a great help in setting up my GPS but I am still confused about the connection data. My outgoing connection reads BT-GPS-306641 and BT-GPS Com Port 1 Can anybody out there tell me whether or not this is right and if not how do I change it. Also, has anybody got any experience of using the HP 4700 with a Seidio Amplified mount I have not bought a mount as yet. If the Seidio is not right can anybody suggest a mount that will fit my 4700 which has a hinged plastic screen cover which seems to foul the sides of the mount. Cheers.
StevenGourlay
PostPosted: Tue Jul 12, 2005 6:00 pm    Post subject: Reply with quote
using the bluetooth connection you should be accessing bluetooth serial port com 8 to connect to your GPS.
Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool
mobile
PostPosted: Tue Jul 12, 2005 9:13 pm    Post subject: Reply with quote
Hi Steven, Thanks a lot for the info I am now on other cable NMEA GPS, baud rate 38400 and bluetooth serial port com 8. I have managed to get a fix and it seems to be working picking up 4 sats from inside the house and I shall be trying it out tomorrow Ken W
CoolJB
PostPosted: Tue Jul 12, 2005 9:47 pm    Post subject: 4700 Reply with quote
Now you have got it working wired you should be able to set it up as other bluetooth, anyway that worked for me! I use a 4700 with one of those silver colour mounts sucks onto windscreen and works fine, i have found i don't need any amplification "Jane" can be heard over car radio as you can increase her volume if required. Only problem I've had with mount is after a while it falls off! Fortunately not yet with 4700 in it! Still it is no problem to put back on, or if you find any better mounts please let me know!
mobile
PostPosted: Wed Jul 13, 2005 10:18 am    Post subject: Reply with quote
I will see how loud Jane is before buying an amplified mount. I will keep you posted. Ken W
scoobydoo711
PostPosted: Wed Jul 13, 2005 1:44 pm    Post subject: Reply with quote
I use an Arkon CM705 Powered mount which I picked up on ebay, have a look at the link below:
http://www.morpethmobiles.co.uk/proddetail.asp?prod=x19&cat=114
You can either fold the plastic cover all the way round behind the PDA or remove it simply when using the mount.. By the way the powered speaker is of help when wife and 3 kids are bickering, anyone of them can drown out Jane....
Scooby Smile
mobile
PostPosted: Wed Jul 13, 2005 7:04 pm    Post subject: Reply with quote
Hi Scooby, I tried it out today and you are right jane is not load enough so I will get an amplified mount off ebay. With regard to the cover I did not realize that you could take it off. Thanks for the tip Cheers Mobile
22.062 (12 Jun 24)
