barleymo Occasional Visitor
Joined: Oct 14, 2004 Posts: 23 Location: United Kingdom
Posted: Wed Jul 06, 2005 1:10 pm Post subject: Postcodes |
If it is only giving you 5 digit postcode functionality, I am fairly sure that it cannot see the postcode database.
I found that when I installed TTN5 it put the folder "ZIP" which contains the post code data onto the root of the SD card. A colleague told me it should be on the root of the PDA instead. I moved it there and the 7 digit postcodes worked fine. |
Posted: Wed Jul 06, 2005 1:34 pm Post subject: Please ignore |
Clicked New topic instead of post reply. |
Solly Occasional Visitor
Posted: Wed Jul 06, 2005 9:57 pm Post subject: |
Ifyou have put in the ZIP file as suggested, then when you go to naigate select Postcodes instead of city and you will get the full postcode functionality. |
Oldie Pocket GPS Moderator
Joined: 22/11/2002 13:33:48 Posts: 992 Location: Surrey, UK
Posted: Thu Jul 07, 2005 12:29 pm Post subject: |
If the ZIP folder is on a storage card then you also need a folder named TomTom on the card. There is no need to put anything in the TomTom folder.
Richard _________________ Various TomToms, Garmin eTrex Legend, GPSMAP 60CSx, Oregon 550t, Forerunner 405 |
westentertainer Frequent Visitor
Posted: Fri Jul 08, 2005 4:08 pm Post subject: |
hello my full code searches are not working [i need them for my job] i have created a tomtom folder but when i put in 7 didgit search it still asks me for street etc could you be so kind as to give me step by step instructions many thanks |
Posted: Fri Jul 08, 2005 4:09 pm Post subject: |
antrichards Occasional Visitor
Posted: Fri Jul 08, 2005 4:38 pm Post subject: I can't find the ZIP file |
I've tried all the listed solutions, but still can't use the full postcode function. I've looked on my card and PDA but can't find the ZIP file - any ideas where it might be? |
frank11 Occasional Visitor
Posted: Fri Jul 08, 2005 4:54 pm Post subject: |
You have to install the zip file from CD 1
CD1\AddMaps\GreatBritain\GreatBritain Postcodes |
Posted: Fri Jul 08, 2005 6:52 pm Post subject: |
well i checked inside tomtom folder to see if it was empty like it should be i found there was a voice i use so i created a folder called tom tom . [note the dot] because you cant create 2 folders the same and ay prest it worked many thanks |
Posted: Sun Jul 10, 2005 12:38 pm Post subject: Thanks very much |
Found the ZIP folder on my CD ROM and works like a dream! |
Posted: Sun Jul 10, 2005 1:10 pm Post subject: I lied..... |
I found the ZIP folder and copied it to the My Documents folder on my PDA and ensured the was a folder called 'TomTom' there as well. Started up TTN5 and still the 3 digit postcode search. Moved the ZIP folder to my SD card and made sure there was a 'TomTom' folder there which was empty. Still no joy! Is there any way of just telling TTN5 where to look for the postcode data? I'm at the end of my tether! |
Oldboy Pocket GPS Moderator
Posted: Sun Jul 10, 2005 1:37 pm Post subject: |
You will need to create a directory at the same level as the map directory. So depending on where your Map Directory is you would see the following -
Map Directory
tomtom
zip _________________ Richard
Posted: Sun Jul 10, 2005 3:16 pm Post subject: |
Quote: | Started up TTN5 and still the 3 digit postcode search. Moved the ZIP folder to my SD card and made sure there was a 'TomTom' folder there which was empty. Still no joy! Is there any way of just telling TTN5 where to look for the postcode data? I'm at the end of my tether |
Are you using Navigate to.... Address then imputting Postcode
To get the full Postcodes you have to use
Navigate to....(then on the second page) Postcode
Frank |
