Pocket GPS World :: View topic - Help - Error Message: Not enough free space on temp folder..
RichA
PostPosted: Sun Jul 03, 2005 6:07 pm    Post subject: Help - Error Message: Not enough free space on temp folder.. Reply with quote
Have installed TT5 on my 2210.
Now inserted map disk 1.
Get the following pop up...
"Not enough free fpace on temporary folder.
Cannot run Setup."
Any ideas?
Thanks.
radavis
PostPosted: Sun Jul 03, 2005 6:10 pm    Post subject: Reply with quote
Do a search of this site or the the TomTom web site for the answer as it has been mentioned a number of times before. Evil or Very Mad
Conor
PostPosted: Sun Jul 03, 2005 7:04 pm    Post subject: Reply with quote
Look for an application called CCleaner. Download it, install it and run it. It'll clean out the contents of the temp folder and also solve the problem.
tungstentim
PostPosted: Sun Jul 03, 2005 7:14 pm    Post subject: Reply with quote
The right thing to do is to load the installer onto your pc and run it from there. I've a 2215 and suffered from the same issue. As did other people.
Tim
grizzlie
PostPosted: Sun Jul 03, 2005 8:58 pm    Post subject: Reply with quote
Just look on TomTom site this obviously happens a bit because they tell you what to do.
I had the same problem and their answer solved my error
nearlylost
PostPosted: Sun Jul 03, 2005 10:21 pm    Post subject: Reply with quote
If you get this message when you attempt to install TomTom NAVIGATOR 5 Upgrade pack please follow these steps:
1. Remove the CD-rom from your CD-rom drive.
2. Click on Start, select Run and type %temp%, then press OK.
3. Select the file setup.exe and delete this file by tapping delete on your keyboard.
4. Insert your NAVIGATOR 5 Upgrade CD-rom into the CD-rom drive.
5. Now you can install your TomTom NAVIGATOR 5 Upgrade.
22.055 (29 May 24)
