dragon01 Occasional Visitor
Posted: Thu Jun 30, 2005 3:52 pm Post subject: TOM TOM GO 300 Traffic Cam Voice Alerts |
I have a new Tom Tom 300 using the latest 5.2 software and have downloaded the traffic cam POI's and modified voice alerts to give more detail lik 'Gatso 30' or such. The POI's all alert in the right places and the voice alert comes on but where its a GATSOor TEMP POI it only gives one voice which ever is selected in the menu of the TOM TOM for voice alerts for that type of POI. It will not indicate that they are in the speed range 40,50 or 60 despite the fact that the screen comes up with a Cam pic and the numerals 30 or such under it. I have just downlaoded the latest version of the modified Voice Commands for the 5.2 version. Have I done something wrong or is this the way it works. Any help that can be given on this subject would be greatly appreciated. My email address is dragon001uk@yahoo.co.uk. Many Thanks. |
Oldboy Pocket GPS Moderator
Posted: Thu Jun 30, 2005 6:59 pm Post subject: |
You have to go into Manage POI and select Warn When Near. Then as you step through the menus you can select the correct voice for each alert. _________________ Richard
Posted: Thu Jun 30, 2005 7:22 pm Post subject: |
Oldboy wrote: | You have to go into Manage POI and select Warn When Near. Then as you step through the menus you can select the correct voice for each alert. |
Richard, I have done this through the POI setup but it only allows you to set up one voice function for say Gatso . It does not allow you to set up all the sounds for Gatso like 'Gatso 40' I appreciate that some of the POI's may not have the information as to the speed of that particular cam but having tried it with a know POI that has got the speed in the data as it shows on the screen it still gives the standard Voice as I have set for Gatso. |
Jim-Bob Regular Visitor
Joined: Apr 28, 2005 Posts: 125 Location: Yorkshire, England!
Posted: Thu Jun 30, 2005 7:33 pm Post subject: |
How many speed cam .ov2 files did you add to your TTG? |
You have to go into each and every POI and select a different sound for each one. Reading through your post again, I would hazard a guess that you have copied the main Gatso file from the ov2 and bmp folder as well as the speed zoned files.
You should have 17 files only if you are using the Speed Zoned files, or 5 files if using only the Camera Type files.
Just check how many you have. _________________ Richard
Posted: Thu Jun 30, 2005 8:01 pm Post subject: |
Oldboy wrote: | You have to go into each and every POI and select a different sound for each one. Reading through your post again, I would hazard a guess that you have copied the main Gatso file from the ov2 and bmp folder as well as the speed zoned files.
Just check how many you have. |
I have downloaded all 17 files into the Great_britain folder and when I do a test of all the diff voice POI's I get all the correct replies as per the list in the downlaod information. Its only when the Tom Tom uses the voice commands in connection with a route it just uses the one name and that is the name I set againt that type of POI . Should I have several lots of POI's loaded in each type like Gatso 30 or is that info picked up from the data when it uses the POI data. |
Posted: Thu Jun 30, 2005 8:11 pm Post subject: |
Do you have the pocketgps_uk_gatso_tba file or the pocketgps_uk_gatso file?
dragon01 wrote: | Should I have several lots of POI's loaded in each type like Gatso 30 or is that info picked up from the data when it uses the POI data. |
Not sure what you mean by this but you should have one .ov2 file for each cam+speed. |
sgould Frequent Visitor
Posted: Thu Jun 30, 2005 8:23 pm Post subject: |
You need these in your GB map folder along with the matching .bmp files:
pocketgps_uk_specs.ov2
pocketgps_uk_gatso_50.ov2
pocketgps_uk_mobile_70.ov2
pocketgps_uk_gatso_40.ov2
pocketgps_uk_mobile_50.ov2
pocketgps_uk_gatso_60.ov2
pocketgps_uk_redlight.ov2
pocketgps_uk_mobile_30.ov2
pocketgps_uk_mobile_60.ov2
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_70.ov2
pocketgps_uk_gatso_tba.ov2
pocketgps_uk_mobile_40.ov2
pocketgps_uk_temp.ov2
pocketgps_uk_mobile_tba.ov2
pocketgps_uk_mobile_20.ov2 _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
