Pocket GPS World :: View topic - Where did TomTom get the postcodes from for TTN5?
GerryC
PostPosted: Thu Jun 23, 2005 9:46 pm    Post subject: Where did TomTom get the postcodes from for TTN5? Reply with quote
When I upgraded, I thought I'd check some "known" postcodes to see how it works. It's disappointing to see that not only is my current postcode going to the wrong street, so is my parents and where I'm moving to. Confused
Each time, it has a different road on the same estate. I can only guess that they plotted a single point for each postcode and then took the nearest street name to that point. If so, this would seem to be a bit dodgy.
If they had checked against ANY official postcode system, they would have had the right road name and maybe would have been able to plot the dot in the right place (ie on the road it refers to).
Is this a general problem across the country or am I just extremely unlucky? :x
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
julianbarker
PostPosted: Thu Jun 23, 2005 9:52 pm    Post subject: Reply with quote
I have been using the postcodes ot navigate ot farms - TT gets me straight to the farm gate in most cases, just sing the postcode.
nnishp
PostPosted: Fri Jun 24, 2005 1:15 am    Post subject: Reply with quote
i have this problem too, my road doenst come up as my postcode on ttn5, it takes me elsewhere
PostPosted: Fri Jun 24, 2005 6:40 am    Post subject: Reply with quote
Each Postcode generates a lat/long which TT then links to the nearest road. Then a house number, or crossing, is requested for added accuracy.
If roads are close together it is possible for TT to latch to the wrong road.
jupiter
PostPosted: Fri Jun 24, 2005 11:58 am    Post subject: Reply with quote
Hmm. The postcode app that digitools used to do was excellent until he had to take it off due to copyrights! :x
sland
PostPosted: Fri Jun 24, 2005 12:12 pm    Post subject: Reply with quote
I use the postcode program from Jose Adell. It works with TT5 and I find it excellent. Not free but very reasonably priced.
See http://pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=23045 for info on where to get it.
Rgds,
Mike
Nomada
PostPosted: Fri Jun 24, 2005 12:45 pm    Post subject: Reply with quote
Hi All
That's the way Niels add-on or mine works, but not sure at all is the system TomTom adopted.
I stand to be corrected, but Postcodes in TomTom only will work if you have the map for them.
TomTom Postcodes came from TeleAtlas maps and they are linked to objects in the map. Again standing to be corrected.
I did proposed time ago a test: May be somebody knows a new settlement, made in the last two years, that still not in maps, but with well known postcode.
Just type the postcode and let us know if you get it. Even in midle of nowhere, like woudl be the case with digitools add-on or mine.
That could enlight if postcodes and objects in maps are or not dependants and if they are then to be in a place or other is just an error in the database.
Jose Adell
www.geopostcode.com
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
blurredout
PostPosted: Fri Jun 24, 2005 12:54 pm    Post subject: Reply with quote
I am interested in knowing what maps people are using when they get these problems, are they the GB map or the GB PLUS map?
Also could someone give some example postcodes that show this problem.
julianbarker
PostPosted: Fri Jun 24, 2005 2:23 pm    Post subject: Reply with quote
You have to be careful with postcodes - in the past I have used navigation systems based on full post codes which have failed - for example, becasue the property is new and the post code in the database shows the post code as being at the local sorting office, not at the new street (even where the street is included) - or, in the case of a buisness that had its own postcode - the business moved and took the post code with it, but the database had not been updated. Similarly, I have found that navigating to Government Offices by postcode can be pointless as the postcode may refer to the location post is delivered and sorted, not to the location of the building in the address.
PostPosted: Fri Jun 24, 2005 6:24 pm    Post subject: Reply with quote
The TomTom Postcode file will apparently work with the older maps, so I assumed that they return a lat/long similar to a normal Navigate to Address.
Nomada
PostPosted: Sat Jun 25, 2005 12:52 am    Post subject: Reply with quote
Hi Oldboy,
It could be, I don't know. I just know what I was told by OS about the way postcodes are bundled in TeleAtlas maps, as they proceed too from OS.
Jose Adell
www.geopostcode.com
TomTom-Paul
PostPosted: Sat Jun 25, 2005 1:20 am    Post subject: Reply with quote
blurredout, try B6 4AA in either of the uk maps.
It should point to St Stephens Street which is due north of where it does point.
Geopostcode got it right.
Paul
Nomada
PostPosted: Sat Jun 25, 2005 1:32 am    Post subject: Reply with quote
Hi Paul
Paul
Well, I want to be honest here. I did check it and my add-on and ttn5, withouth any house number, then both are in the same point. What happens is that TTN5 gives it for High Street as it is the nearest street. But look at the cursor in the centre of the screen, it is the real position for the postcode, whilst High Street is on the left of the screen.
Jose Adell
www.geopostcode.com
TomTom-Paul
PostPosted: Sat Jun 25, 2005 1:42 am    Post subject: Reply with quote
Embarassed
I thought you had to enter a house number when it asked.
Paul
Nomada
PostPosted: Sat Jun 25, 2005 1:46 am    Post subject: Reply with quote
Hi Paul,
TomTom-Paul wrote:
Embarassed
Paul
I think to have read in this forum house number are just shared proportionally in the leg of street in TomTom program, but not for real.
When I was working as courier I tried several times to include the house number, only to get away from the place. Postcode was much more accurate.
Jose Adell
www.geopostcode.com
