Pocket GPS World :: View topic - TT5 can't remember my favourite..........
ian57
PostPosted: Mon Jun 20, 2005 7:50 pm    Post subject: TT5 can't remember my favourite.......... Reply with quote
Hi anyone else having probs after setting up home location & any favourites, then close TT in the proper way, and then they have gone!! Evil or Very Mad
Have had 2 add as a POI for my home location, strange cos any POI added is saved, also any poi ticked to display get unticked when restarted as does adding warning sounds to a POI they get unticked.
Is it just me as I have'nt seen any postings yet?? Embarassed
Miss the options in map mode from TT3 Sad
Ipaq 2210 :D
silversurfer
PostPosted: Mon Jun 20, 2005 8:44 pm    Post subject: post subject Reply with quote
i had the same problem andwas told to make sure the sd card was set to unlock as poi are stored on the sd card , you could give that a try
_________________________
chris
ian57
PostPosted: Mon Jun 20, 2005 10:32 pm    Post subject: Reply with quote
Hi thanks for info have tried that, not had a prob with active sync changing files on Sd card so i no i can write to card.
Strange prob 4 me all user change's I make / add 2 TT are always there, .........until I have 2 restart TT, then gone, favourites, POI ticked, POI warning sounds etc.
Does anyone no where my settings r saved 2??
linknet
PostPosted: Mon Jun 20, 2005 10:53 pm    Post subject: Reply with quote
TTN5 stores the map settings in the map folder in a .cfg file with the same name as the map folder.
For example: The Great_Britain map settings are in the file Great_Britain.cfg in the Great_Britain-Map folder.
Maybe this file is somehow read only?
ian57
PostPosted: Tue Jun 21, 2005 11:49 am    Post subject: Reply with quote
Spot on sorted, Many thanks Linknet. Almost getting 2 like TT5 now!!
Just 1 other prob some of my POI are saying No POI found !!
Yet they are showing up in the maps, any ideas??
jupiter
PostPosted: Tue Jun 21, 2005 1:16 pm    Post subject: Reply with quote
How do you de-select the read only box from the sd card. WHen I explore it via active-sync it is greyed out??
THanks
linknet
PostPosted: Tue Jun 21, 2005 2:03 pm    Post subject: Reply with quote
Hi Ian - Glad that helped.
Try:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=22293
I'm having this problem and can't find a solution. I originally thought my PDA had incompatibility problems but with so many people having the same fault I'm now inclined think it's a bug in the software.
You'll find some short term solutions amongst the posts but none 100% effective.
I also think that many people will have this fault and not realise, they'll just think that there are no POI's and accept the message at face value.
Roger
linknet
PostPosted: Tue Jun 21, 2005 2:10 pm    Post subject: Reply with quote
Try using a card reader, it's also a lot faster.
Doghead
PostPosted: Wed Jun 22, 2005 4:14 pm    Post subject: Reply with quote
I installed the TT Nav 5 with maps to SD card.
Wanting a backup I put them to CF card as well. When running TomTom Navigator 5 with only the CF card in, it doesn't remember my "Home" location, nor does it allow me to input the "Home" location.
Presumably its some data TomTom Navigator 5 added to the SD card when setting Home location, but how can I now set the Home location to work with the other CF card ?
Doghead
PostPosted: Wed Jun 22, 2005 4:46 pm    Post subject: Reply with quote
I've just jury-rigged a working solution to my "Home" problem with 2 cards, SD and CF, but surely there is an easier way. With two slot PDAs commonplace, doesn't TomTom expect people may keep a backup of map data on a second card in case the first card should fail ?
Deleted all the TomTom files from the CF card. Used a card-reader and copied the all data from original card used, the SD card, across to the desktop. Then copied those files across to the CF card.
Now got the "Home" set/select working and clickable from both cards.
simonpearce
PostPosted: Tue Jun 28, 2005 4:16 pm    Post subject: Reply with quote
I'm also having this problem on my XDA2i.
I spent ages inputting favourites to find they've all disappeared Sad
The file isn't read only and the lock is off the card - any ideas?!
Simon
Escargot
PostPosted: Wed Jun 29, 2005 12:13 am    Post subject: TT5 can't remember my favourite.......... Reply with quote
Can I join the club?
My TT5 running on iPAQ 4150 will also not remember Home, Favourites, POI settings etc. once it is turned off.
I checked the Great-Britain-Map.cfg as suggested and sure enough it shows up as read only, with the option to change this greyed out.
As I don't have a card reader I thought I'd be clever and I copied the file to my 'C' drive, where I could view it's properties and change them, deselected the tick in the read only box, applied the change and then copied the file back to my SD card. That didn't work!! Lo & behold it had changed back to read only again.
can anybody suggest a fix for this??
frank11
PostPosted: Wed Jun 29, 2005 12:56 am    Post subject: Reply with quote
did you delete the file from your sd card before you copied it back, other wise it will not save the changes
Frank
Escargot
PostPosted: Thu Jun 30, 2005 9:40 pm    Post subject: Reply with quote
No I didn't! But I tried again and it worked.
Thanks..
22.055 (29 May 24)
