ScaredyCat Regular Visitor
Posted: Sun Jun 19, 2005 10:53 am Post subject: |
Ok, thanks lutz,
lbendlin wrote: | The second bank is required for TTM. |
I've modified it and removed the version stuff, now you just select the file and it's up to the user to know which version (4.42/5.0 etc) system it came off. Unchecking the 'Yes, my device is a TTG' checkbox will result in the second bank being set as the target for the sound files.
SC |
lbendlin Pocket GPS Staff
Posted: Sun Jun 19, 2005 1:17 pm Post subject: |
I would recommend that you always fill both banks, the first with 22050 and the second with 16000. You also have to target the Pocket PC, the Palm, and the UIQ, and with this approach you catch them all. And you can remove that checkbox too. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sun Jun 19, 2005 1:53 pm Post subject: |
lbendlin wrote: | I would recommend that you always fill both banks, the first with 22050 and the second with 16000. You also have to target the Pocket PC, the Palm, and the UIQ, and with this approach you catch them all. And you can remove that checkbox too. |
Both banks are filled regardless of the state of the checkbox, however, only the appropriate bank is *changed* depending on the state of the checkbox.
ie. If bank 1 is being changed then bank 2 just contains the original sounds.
SC |
Posted: Sun Jun 19, 2005 2:01 pm Post subject: |
ok, let me rephrase. I would recommend you always CHANGE both banks.
8) _________________ Lutz
KenJ Occasional Visitor
Posted: Sun Jun 19, 2005 8:19 pm Post subject: |
ScaredyCat, I can't seem to get the app working with TTN5 ver 4890 ? Works with eveything else ? |
Posted: Sun Jun 19, 2005 8:24 pm Post subject: |
Version 4890 seems to have 137 modules. |
Posted: Sun Jun 19, 2005 10:07 pm Post subject: |
KenJ wrote: | Version 4890 seems to have 137 modules. |
Hi KenJ,
Ok, I'm assuming you get the error about it being a bad .chk file - is that correct? Can you send me a copy of the data.chk file from the TTN and I'll take a look
SC |
shazbot Occasional Visitor
Posted: Mon Jun 20, 2005 11:05 am Post subject: DATA.CHK file |
I dont seem to have a data.chk file on my tomtom go, i can only see DATA01, DATA04, DATA05, DATA, what am i doing wrong? |
Jim-Bob Regular Visitor
Joined: Apr 28, 2005 Posts: 125 Location: Yorkshire, England!
Posted: Mon Jun 20, 2005 11:56 am Post subject: |
The data.chk is the DATA file you have. The .chk is the file type. |
Posted: Mon Jun 20, 2005 2:07 pm Post subject: |
You don't see the .CHK extension with the Pocket File Explorer. Use Resco Explorer or any other tool that doesn't hide extensions. _________________ Lutz
Posted: Mon Jun 20, 2005 4:00 pm Post subject: |
Just a quick note,
with the release of 5.2 firmware the app is broken, I noticed that the data.chk file for the TTG have changed in size...
looking at it now...
SC |
Posted: Mon Jun 20, 2005 4:17 pm Post subject: |
New version released.
Please be aware this version treats you like an adult. If it doesn't recognise the number of modules it will tell you, but it WILL give you the option to continue (or cancel).
http://www.automated.it/ttg-poipatcher.html
SC |
Posted: Mon Jun 20, 2005 4:27 pm Post subject: |
Sorry,
just a quick warning...
I seem to have a problem talking to my TTG via the usb cable.
Just installed 5.2 and now I can't talk to it via the usb cable. Just gives a new screen telling me not to remove the cable, then I see the picture of the TomTom and finally it goes into normal operation (navigation mode)
SC |
Posted: Mon Jun 20, 2005 4:30 pm Post subject: |
ok, nm, panic over
Reset fixed it...
although it did try to detect the ttg as a new usb device needing a new driver
SC |
Posted: Mon Jun 20, 2005 4:38 pm Post subject: |
Ok, version 5.2 with poipatcher results in silent sounds for the ones you patch - unpatched seem unaffected.
Researching it atm
SC |
