Pocket GPS World :: View topic - REVIEW COMMENTS: TomTom Navigator 5 Palm & Pocket PC
Goto page Previous  1, 2, 3 ... 19, 20, 21 ... 23, 24, 25  Next
Pedro-G
PostPosted: Fri Jun 17, 2005 4:12 am    Post subject: Re: Postcodes Reply with quote
I've been using the BT338 and TomTom's Bluetooth MKII GPS's for a while now and they really are a revelation in performance terms.
This was on May 27, still no review on the new Tomtom GPS unit?
lydiachris
PostPosted: Fri Jun 17, 2005 12:09 pm    Post subject: Reply with quote
Just got my Nav 5 today and its installed perfectly.
Had a couple of lock-ups, just because the signal on my XDAIIi was lost. Has anyone else had the same problem???
Robin2
PostPosted: Fri Jun 17, 2005 4:49 pm    Post subject: Reply with quote
Try rotating it to landscape view. The speed (and other info) is much larger
Robin
Satmap Active 10
MrJones
PostPosted: Fri Jun 17, 2005 7:49 pm    Post subject: Reply with quote
Just installed the upgrade travelled round London then back to Birmingham, the map and speed is a lot better going round islands works better.
Postcode now works ok, after i went back and found were to install it from
I did miss my checkpoint, but im hoping it will come soon please
Tried the traffic did not think much of it, but will give it a go.
all in all a thumbs up :D
Dell Axim 5
TTN5
TomTom wired GPS
NigelJ
PostPosted: Sat Jun 18, 2005 11:23 am    Post subject: Reply with quote
Can anybody tell me if TT5 works with a Compaq 3950?
Sorry - I thought I had seen the information somewhere but cannot find it now!!
Nigelj Embarassed
cphine
PostPosted: Sat Jun 18, 2005 7:06 pm    Post subject: TTN5 on Palm T3 Voice Problems Reply with quote
I have upgraded to TTN5 on my Palm T3.
Everything seems to have installed correctly with the exception of the voices. I have no voices installed, not even 'Jane' and have 9.2Mb free space on my SD Card.
Does anyone know how to manually install voices on a T3? If I use the installer, everthing seems to be fine but I can't access any voices at all.
Chris Hine
bond007
PostPosted: Sun Jun 19, 2005 9:41 am    Post subject: Reply with quote
OK chaps,
I received my TT5 within one week of placing the order Smile
First impressions:
1. Interface - An improvement for "on the go driving". No more need to use the stylus as one had to in TT3 (most of the time).
2. On the route summary screen there is a big waste of space where your satellite info is. Also on the navigator screen, the blue information section is too big.
3. The rotate screen function is cool, but no good to be as my pda holder does not rotate Crying or Very sad
4. My EMTAC BT CRUX II works well with my IPAQ 3970. Even using the "Other BT" option in the configuration. This did however take time to setup!
OK the bad things..
5. The application is slower than TT5. Also sometimes it will run normally, other times it runs fine.
6. When you exit the application and then want to restart it TT5 will not restart. I have to do a soft reset! :x
I have yet to use it in anger, but will do today.
cheers
b
PostPosted: Sun Jun 19, 2005 9:47 am    Post subject: Re: Postcodes Reply with quote
The TomTom MKII GPS I have is an early sample, we were awaiting a final production version before releasing a full review.
In summary though, it performs excellently, perhaps very slightly less sensitive than the BT338 but this may be die to its being an early sample. It lacks a user replaceable battery but is smaller and slimmer, perfect for hanging around your neck on a lanyard.
It also has the auto power off feature to save battery when no active BT Connection is present and tests show its battery life at between 8-10hrs in heavy usage.
bond007
PostPosted: Sun Jun 19, 2005 9:53 am    Post subject: Reply with quote
Please correct me if I am wrong, but I have read on some website that the new TomTom MKII GPS BT receiver is not compatiable with WAAS and EGNOS. Is this correct. This will mean that we will not be able to use the new European GPS satellites which are supposed to be more accurate than the current American GPS satellites.
I am using the EMTAC BT (SIRF 2) which is WAAS & EGNOS compatiable. Just need to know how to switch over to using this 'standard'.
PostPosted: Sun Jun 19, 2005 10:04 am    Post subject: Reply with quote
WAAS and EGNOS have nothing to do with the European Galileo GPS Constellation.
WAAS & EGNOS is a method of using ground based stations to error correct poistion data via satellite. It allows a greater degree of posutional accuracy but is of little practical use for in car navigation, indeed SiRFStarIII is sufficiently accurate to make WAAS/EGNOS all but redundant for most uses aside from survey where high levels of accuracy are essential.
See here for a detailed explanation of EGNOS. WAAS is the US version of the same service.
EGNOS is till in the test phase and so cannot be relied upon anyway!
efthimios
PostPosted: Fri Jun 24, 2005 12:55 pm    Post subject: TTN5 Comments Questions. Reply with quote
Just got my ttn5 upgrade. I use it on an HP6315 and it works fine.
It is a kind of a learning curve though. In ttn3 I found very usufull the tap and hold menu. In ttn5 I cannot easilly plan routes in advance. Also adding a POI is more tricky.
Also I got a Go700.
There is a detailed map of Athens Greece in the Go 700 that is missing from the map set of the PPC product.
Another think that I was waiting for was the integration of the phone with the software. I am not able to use my phone while in ttn5 and I have to exit from the programm since I cannot go to the start menu. I cann use the phone with the speed buttons but then the device is becoming a bit slow.
This is very annoying to me because everytime I need to make a call or use some other software on my PPC I have to shutdown the TTN5.
Also there is no commant to edit an existing POI. I guess the only way is to delete it and add it again.
Waiting for your comments.
sam1970
PostPosted: Fri Jun 24, 2005 7:08 pm    Post subject: Reply with quote
hi every one
please excuse me if my question sounds daft but i have been using tt 3 for just over a year now (GB and major roads of europe) but i never needed to download europe maps.....I have just recieved the email for upgrade today and my question is if i buy the upgrade will i be getting any more detailed maps for europe or is it the same (ie major roads)...and what do they mean at tt website by the note that when you upgrade your region you dont need to update maps of western europe????...any advice will be appreciated
PostPosted: Fri Jun 24, 2005 7:23 pm    Post subject: Reply with quote
The upgrade gives you street level map data which is far more detailed than the Major Roads of Europe (MRE) mapset.
So when you upgrade you will get the latest product version and a set of CD's containing the street level maps for each country in Europe covered by the Maps of Western Europe (MOWE) mapset.
sam1970
PostPosted: Fri Jun 24, 2005 8:20 pm    Post subject: Reply with quote
thank you very much Darren....cant be more helpful
Flying-Low
PostPosted: Sat Jun 25, 2005 5:56 pm    Post subject: Got my upgrade Reply with quote
Hi All,
I got my TT5 upgrade and installed it on my Pocket Loox 600 (TT say it is not compatable). I did a full hard reset frst and did not reinstall TT3. I use a Fortuna Clip On BT GPS. It works fine and it recognised my BT GPS with no problems. I like it but I miss:
Being able to 'block' a road - Jane insists on taking me down a country lane ( Smile ) to get to a major road when there is a perfectly useable main road!
Being able to customise speeds
Being able to customise what appears on the menu but I suppose I will get used to it. Just need to get the full 7 digit postcode working properly.
Barry
Page 20 of 25
