Pocket GPS World :: View topic - Change TT5 menu possible
Goto page Previous  1, 2, 3, 4, 5 ... 11, 12, 13  Next
newmikey
PostPosted: Thu Jun 16, 2005 9:02 am    Post subject: Re: post subject Reply with quote
silversurfer wrote:
thanks for that information
i installed a new folder in the tomtom folder with the bmp files in called SDKRegistry as you implied and then copyed the mns file over , but its still not working for me , i used the msu file from Spark1e post here
many thanks
I get a little confused by you stating you "copyed the mns file over" and then " i used the msu file".
The file should be called TomTom.mnu
Check if you got the upper/lowercase right in the name, no empty lines in the file or at the end (except for one closing CR/LF) and check if every line is closed off with a "|".
I hope that helps.
silversurfer
PostPosted: Thu Jun 16, 2005 9:20 am    Post subject: post subject Reply with quote
many thanks to newmikey and Spark1e i now have this feature working :D
_________________________
chris
newmikey
PostPosted: Thu Jun 16, 2005 9:23 am    Post subject: Re: post subject Reply with quote
Clap Hey, hey! Another satisfied consumer! Glad to hear it worked out.
BTW: if anyone has an issue with the map not moving smoothly, but in jerks, there is a solution for that as well!
silversurfer
PostPosted: Thu Jun 16, 2005 9:23 am    Post subject: post subject Reply with quote
newmikey sorry abot that but still learning to type with two fingers Embarassed
chris
jweaver
PostPosted: Thu Jun 16, 2005 9:40 am    Post subject: Reply with quote
newmikey,
Yesturday you said that other Palm users had got this working, but I still havn't found any evidence of this.
Could you please confirm as I have tried and tried and tried to get this working and am now convinced that its simply not going to happen on the Palm!
Jon
Robocop
PostPosted: Thu Jun 16, 2005 9:41 am    Post subject: Reply with quote
Works well.
Thanks Smile
newmikey
PostPosted: Thu Jun 16, 2005 10:07 am    Post subject: Reply with quote
jweaver wrote:
newmikey,
Jon
Trying, Jon, trying. I can't get onto pocketnavigation.de because of some security issue with our firewall. It doesn't like the board SW used over there I guess.
Will check again this weekend from home.
Vini
PostPosted: Thu Jun 16, 2005 10:53 am    Post subject: Reply with quote
Code:
MENUBLOCK|BLOCK_MAIN|BTM_GPS_POSITION|
MENUPAGE|TASK_PAGE1|Main Menu 1|
MENUITEM|TASK_NAVIGATE_TO|
MENUITEM|TASK_SHOW_MAP|
MENUITEM|TASK_DELETE_ROUTE|
MENUITEM|TASK_CONFIGURE_POI|
MENUITEM|TASK_EXIT_APP|
MENUITEM|TASK_PAGE2|
MENUPAGE|TASK_PAGE2|Main Menu 2|
MENUITEM|TASK_ROTATE_DISPLAY|
MENUITEM|TASK_SWITCH_2D3D|
MENUITEM|TASK_SWITCH_NIGHTVIEW|
MENUITEM|TASK_ADD_FAVORITE|
MENUITEM|TASK_ITINERARY|
MENUITEM|TASK_PAGE3|
MENUPAGE|TASK_PAGE3|Main Menu 3|
MENUITEM|TASK_MENU_FIND_ALTERNATIVES|
MENUITEM|TASK_SHOW_ROUTE_DEMO|
MENUITEM|TASK_PLAN_VIA|
MENUITEM|TASK_MENU_ROUTE_INSTRUCTIONS|
MENUITEM|TASK_AVOID_ROUTE_LINE|
MENUITEM|TASK_PAGE4|
MENUPAGE|TASK_PAGE4|Main Menu 4|
MENUITEM|TASK_SET_MAP|
MENUITEM|TASK_MANAGE_MAPS|
MENUITEM|TASK_SWITCH_POI|
MENUITEM|TASK_RESET_SETTINGS|
MENUITEM|TASK_PAGE5|
MENUPAGE|TASK_PAGE5|Main Menu 5|
MENUITEM|TASK_SHOW_GPS_STATUS|
MENUITEM|TASK_SWITCH_BLUETOOTH|
MENUITEM|TASK_MAINTAIN_FAVORITES|
MENUITEM|TASK_DELETE_MAP|
MENUITEM|TASK_CHANGE_HOME_LOCATION|
MENUITEM|TASK_PAGE6|
MENUPAGE|TASK_PAGE6|Main Menu 6|
MENUITEM|TASK_MENU_PREFERENCES|
MENUITEM|TASK_ABOUT|
MENUITEM|TASK_PAGE1|
is the one i use, great find love the customisation!
lads2000
PostPosted: Thu Jun 16, 2005 11:45 am    Post subject: Reply with quote
This is Great well done to the people behind this it almost makes this a perfect product.....
Does Anybody have the code for Postcode so I can display them on the main menus
Booster
PostPosted: Thu Jun 16, 2005 11:53 am    Post subject: Re: post subject Reply with quote
newmikey wrote:
[BTW: if anyone has an issue with the map not moving smoothly, but in jerks, there is a solution for that as well!
And what solution is that ?
Booster
PostPosted: Thu Jun 16, 2005 12:01 pm    Post subject: Reply with quote
Never mind, used the search function and find the solution..
Thx anyway
newmikey
PostPosted: Thu Jun 16, 2005 12:08 pm    Post subject: Re: post subject Reply with quote
Use the POI settings and uncheck all of your imported POI categories (The ov2 files for f.i. speedcams)
Than go to the proximity warning settings (the POIwarner-like thingamajiggie) and mark those same categories for proximity warnings. I used a 400 meter threshold, use what you think is handy.
That's all. The speedcams will still show up when you go anywhere near them, but the map will scroll smoothly again.
The origin of this problem seems to be a different internal handling of the ov2 files by TT5 which causes all external POI's to be redrawn every time you move.
chrisdk
PostPosted: Thu Jun 16, 2005 1:57 pm    Post subject: Reply with quote
Has anyone managed to find the option to rotate the screen 90 degrees (ROTATE_DISPLAY turns by 180)? I've tried several variants of ROTATE_DISPLAY_90, but with no luck.
newmikey
PostPosted: Thu Jun 16, 2005 2:11 pm    Post subject: Reply with quote
Sad Same for me here. I don't really mind as the original 90 degree rotations are still accessible under the PREFERENCES menu. I typically only use it to impress my friends. In the car I set it to landscape and I sort of got hooked on that, seeing more of the surrounding area, streetnames and all.
The only setback here is that the carmount is not really designed for landscape use, so whilst fumbling around, my Asus has dropped to the floor more times than I care to acknowledge. Hope it's not developing a headache Laughing
lads2000
PostPosted: Thu Jun 16, 2005 2:18 pm    Post subject: Reply with quote
Its called.......
Page 4 of 13
22.055 (29 May 24)
