Pocket GPS World :: View topic - Camera database
Camera database
Goto page Previous  1, 2
nich
PostPosted: Wed Jun 15, 2005 7:30 am    Post subject: Reply with quote
thats great
thanks
RichardM
PostPosted: Wed Jun 15, 2005 12:42 pm    Post subject: Reply with quote
I have now installed the camera database but while I am sitting at home the TTG is alerting me to a camera down the road which definitely doesn't exist and black figures underneath a speed camera symbol, change from 75 down to 45. Anyone any ideas what is wrong?
sgould
PostPosted: Wed Jun 15, 2005 1:18 pm    Post subject: Reply with quote
While sitting at home the Go will not be able to tell exactly where you are. You "position" will wander about. The black figures are the distance from the camera, so if the GO thinks you are wandering the distance will change.
If camera is shown in the wrong place, report it to Cameras@PocketGPSWorld.com The database is maintained by the "users" that's why it's still free.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
phantomlynx
PostPosted: Thu Jun 16, 2005 8:50 am    Post subject: Reply with quote
I found it is helpful to edit the name of the files so that he PocketGPS_uk is removed from the names. This way yuo can manage them more easily. (You must of course change the name of the bmp files as well...)
Also you only have to update the ov2 files as the bmp remain the same.
Hope this helps
rkm_hm
PostPosted: Thu Jun 16, 2005 2:40 pm    Post subject: Reply with quote
phantomlynx wrote:
I found it is helpful to edit the name of the files so that he PocketGPS_uk is removed from the names. This way you can manage them more easily.
You will, of course, have to change the filenames every time you update the camera database (at the end of every month).
In case it's of interest, I do the following:
Unzip the new files, and copy the .ov2's which I want into a folder called "Latest_ov2" on my PC. In that folder is a utility called _XRENAME.EXE (which I downloaded from somewhere or other - but you can Google for it) and a small batch file which I wrote called Short_name.bat which contains the following line:
_xrename "pocketgps_"
Double clicking on the batch file renames all the files in the folder by stripping the leading "pocketgps_" from each name. [In my case, I leave the uk bit - but could just as easily get rid of that too].
Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire
RichardM
PostPosted: Thu Jun 16, 2005 11:40 pm    Post subject: Reply with quote
Is there any way I could have somehow got this camera in the wrong place by installing a poi or something, and if so is it possible to delete this one wrong camera without losing all the same poi category?
One other question. Is it possible to increase the size of the speed limit symbols? They are there along with the camera symbol on the route, but are difficult to read while driving
Thanks for the help
rkm_hm
PostPosted: Fri Jun 17, 2005 11:44 am    Post subject: Reply with quote
You can use the Change Preferences/Maintain POI menu to add or delete individual POIs within imported POI categories - but you can't change the built-in POIs. [Be careful when deleting POIs to select "Delete POI" and not "Delete POI Category"!]
Thanks for the help
If you look further up this thread, and find a post from Andy_P2002, you'll find a link to some alternative .BMP files - which may do what you want. [The overall icon size can't be increased, but the number may be clearer in these new files].
Are you using the modified voice promps which say "Gatso 40 MPH" etc. rather than just sounding bells and whistles? If not, this is something for you to investigate because it makes it less necessary to be able to see the icons.
Roger
TomTom via135
RichardM
PostPosted: Fri Jun 17, 2005 11:26 pm    Post subject: Reply with quote
Thanks for the info. I am using the standard sounds so I may have to look into the voice prompts when I get time.
Page 2 of 2
