yossii Occasional Visitor
Posted: Fri Jun 10, 2005 10:30 am Post subject: TomTom 5 VS XDA2 & Globalsat 388 |
Hiya
Ive got a XDA2 and a fab little Glabalsat 388 (bluetooth)
Just got TomTom 5
I cannot get the damn thing up and running.
The software come on fine but under GPS status I get "No GPS device"
I am getting a solid green signal from the satilite (according to my GPS manual that is good becasue the thingie can see the satalite)
I just can't get TomTom 5 to play nice with my BT device
Please help i am loosing my sanity !
Thanks in advance
Yossii |
Posted: Fri Jun 10, 2005 10:32 am Post subject: |
For what its worth I used to use TomTom 3 which worked fine.
Also i have done a hard reset on my XDA
Yossii |
JST Occasional Visitor
Posted: Fri Jun 10, 2005 11:26 am Post subject: |
Hi Yossi,
I guess you mean a GlobalSat BT-338?
If so, then a slid green light means it hasn't locked onto the satellites yet. You need the green light to be flashing. Try standing in full view of the sky for a few moments to give it a chance to lock on.
To configure TT5 I have set the GPS Connection to "Other Cable NMEA GPS", "38400 Baud", Com port 5 (for my Ipaq - may be different for you).
I seems to connect OK. I locked on to 9 satellites this morning. However, I am having a problem with TT5 losing the connection to the GPS after about 45mins. TT3 was fine.
Cheers, Jim |
Posted: Fri Jun 10, 2005 12:42 pm Post subject: |
Ok tried that still no go.
I slapped the tomtom307 to check the bt-388 still worked. Grabbed plenty of satalittes then went to tomtom 5 and still "no gps device"
Any more ideas (well apart from going back to tomtom 3 )
Yossii |
Posted: Fri Jun 10, 2005 1:17 pm Post subject: |
Intresting thing i noticed....
there is a small black and yellow circle which is going round so to speak. Does this mean anything ?
Yossii |
Posted: Fri Jun 10, 2005 1:40 pm Post subject: |
If you mean the one on the that has "hh:mm:ss UTC" by it... Yes, that's good! That means TomTom 5 is recieving data from the GPS (on TT3 it used to be a series of dots moving from left to right)
Does the GPS Status page show any vertical bars? If yes, are they grey or blue. No bars means GPS not seing any satellites. Grey bar means seeing satellites, but not locked on. Blue bar means seen and locked on.
Usually you need a minimum of 3 blue bars to get a fix.
Cheers, Jim |
Posted: Fri Jun 10, 2005 2:08 pm Post subject: |
Little circle thing is moving
Nothing in the bars
the message says " No GPS Device !"
Nothing but 0's for lat, long etc....
Thats in TomTom 5
Settings:
Cable device
Connected to com 5
The TomTom 3 thingie shows locked sat's and stuff. and is quite happy. So i know the Hardware is fine and dandy.
Yours perplexed......
Yossii
(thanks for the replys) |
sjaddy Occasional Visitor
Joined: Mar 31, 2004 Posts: 5 Location: Stevenage, Herts
Posted: Fri Jun 10, 2005 2:49 pm Post subject: |
I had same problem (but with M1000 - the Orange version of XDA2).
To fix I had to connect the bt338 to my pc use SirfDemo and change it from using Sirf to NMEA and then it worked absolutely brilliantly under the NMEA Other cable.
Hope this helps.
If not PM me and I can give you full (hopefully) instructions |
junglejim Occasional Visitor
gianpi Occasional Visitor
Posted: Fri Jun 24, 2005 1:48 pm Post subject: |
remove the battery and replace it.
bye |
