Pocket GPS World :: View topic - TTN5 postcode search
Goto page 1, 2, 3  Next
nnishp
PostPosted: Wed Jun 08, 2005 12:03 am    Post subject: TTN5 postcode search Reply with quote
I dont know if any of you have this problem but whnever i want to find a postcode it always takes me to a road nearby not the actual road. Example, i was putting in my home location so i decided to find it by postcode, i put it in and it came up with a road round the corner not mine. Does any one know whats going on?
julianbarker
PostPosted: Wed Jun 08, 2005 8:18 am    Post subject: Reply with quote
Do you have your own unique postcode? Unless you live in something like Buckingham Palace, you will share your post code with a group of properties.
soweezy
PostPosted: Wed Jun 08, 2005 9:33 am    Post subject: Reply with quote
our street has 290 house numbers (not that many houses though) and 4 post codes
my postcode is specific to a group of houses on this street
anyhow, TTN5 postcode lookup is pants, it seems to work similar to TTN3... LLNN N then select the town, I was under the impression it was going to be LLNN NLL ?
SW
Garmin Zumo 390LM
Houdini
Banned
PostPosted: Wed Jun 08, 2005 9:38 am    Post subject: Reply with quote
Errrr.... your using the wrong screen !
tap main screen... 1st icon navigate to.. right arrow... postcode :D
Happier now ?
Best Wishes.
Lorax
PostPosted: Wed Jun 08, 2005 9:58 am    Post subject: Reply with quote
I had a similar problem with the postcode addon (now no longer available) for ttn3. The first (and only, so far) time I used it, it took me to a street that was parallel to the one i wanted. A completely different street!!
I almost knocked on the wrong door before I noticed.
I don't think you share a full postcode with different streets. That would make the use of postcodes pointless!! Maybe one street name has a postcode and then you just look for the house number (which the postcode addon doesn't seen to let you input).
So why are we being directed to the wrong street?
Lorax
soweezy
PostPosted: Wed Jun 08, 2005 10:12 am    Post subject: Reply with quote
nope, navigate by address or postcode gives the same options LLNN N (town)
map version 562 TTN 5.0
SW
Garmin Zumo 390LM
blurredout
PostPosted: Wed Jun 08, 2005 10:17 am    Post subject: Reply with quote
In the "zip" directory on your SD card, do you have the Great_Britain.Postal file? If not then TTN5 will default to the old TTN3 system of postcode lookup.
soweezy
PostPosted: Wed Jun 08, 2005 2:09 pm    Post subject: Reply with quote
it's in the ZIP folder now, I'd put it in the map folder... Rolling Eyes
SW
Garmin Zumo 390LM
proeliator2001
PostPosted: Wed Jun 08, 2005 3:56 pm    Post subject: Reply with quote
i've installed TTN5 and used the CD to put the postcode bit on (and its in the zip folder) and still its using 3 digit lookup which is fecking useless. Anyone got any ideas why TTN5 isn't seeing the file?
ITs running on a 3970 and was upgraded from TTN2 btw.
joni
PostPosted: Wed Jun 08, 2005 4:49 pm    Post subject: Reply with quote
Same problem here upgrading from 3 on a 2210. What's worse is that the original ukpostcode search doesn't work any more either... Confused
alix776
PostPosted: Wed Jun 08, 2005 5:03 pm    Post subject: Reply with quote
is the zip folder on the ppc or the sd if it on the storage card the zip file should be visible on the first veiw allong woith the 2577 folder and the map file
device Lumia 950 xl
joni
PostPosted: Wed Jun 08, 2005 5:19 pm    Post subject: Reply with quote
The zip file is on the SD card next to the map file...I don't know what a 2577 folder is Embarassed but whatever it is it isn't there.
vlak
PostPosted: Wed Jun 08, 2005 9:35 pm    Post subject: Reply with quote
Try putting the "zip" folder at the root level of your PocketPC (instead of the SD card). That's how I got it working with full postcode.
TuurG
PostPosted: Wed Jun 08, 2005 10:19 pm    Post subject: Reply with quote
Instead of using your pocketpc's memory, leave the ZIP folder on your SD card.
But add a folder TOMTOM to the SD card.
Why this would help? The app searches for a TomTom folder, and then searches for all other folders (VOICE, SCHEME, ZIP,...) alongside of this folder. That's why it works with the postalcodes file stored on the PocketPC; you have a TomTom folder with the activation code and settings on your device, in the root and/or in MyDocuments.
vlak
PostPosted: Wed Jun 08, 2005 10:41 pm    Post subject: Reply with quote
TuurG,
You beat me to it!
That was my next option. I thought it was ridiculous to use the PPC's memory for the file so also tried the exact same thing you suggested above and was just about to post it.
Page 1 of 3
22.055 (29 May 24)
