Pocket GPS World :: View topic - Arkon Multimedia + Emtac BT
sitrap
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Arkon Multimedia + Emtac BT Reply with quote
I have almost what I feel is the perfect configuration with the 3970 running TTN2, Emtac BT GPS and an Arkon CM505 Multimedia mount. However, I could do with some power for the Emtac. The Arkon has a DC output on the side. If I had a cable with a couple of 1.7mm DC connectors at either end, would connecting the Emtac to the Arkon allow it to charge the Emtac? - that would be perfection!
No info with the Arkon to say what the voltage coming out is - just says "DC Out jack on side of cradle lets you charge mobile phone devices".
Can anyone help?
Eagle
The output that you refer to, on the Seidio Mount, which I understand is the same as the Arkon, is 5v 0.8 a. I use one of these mounts and charge my EMTAC BT GPS (when required) using this output. See my post on the Seidio Mount under accessories.
sitrap
Thanks Eagle, I'll see if I can find that! I received my proclip in the post today, the setup is nearly complete!
alienrider
I have the Arkon Multimedia mount and it can charge the ipaq and Emtac (Socket). Beware however, I noticed that my Socket BTGPS ran quite warm when connected to it, and hence only use it when absolutely necessary, I would be interested to hear your views on it once you have given it a try.
B
A difficult problem can be solved more easily by reducing it to the question, "How would Bagpuss handle this?" ;-)
Setup: Garmin 3950LMT + PGPSW CAMS
