tel33 Regular Visitor
Joined: Mar 23, 2005 Posts: 159 Location: UK Portsmouth
Posted: Tue May 10, 2005 3:48 pm Post subject: |
Hi there
I think this has been said in this thread or another one that the Naviagtor file is missing in V4.
All I can say is if you got to:
http://www.navigating.de/MN_en/POI/Index_Choice.htm
They have a system that should run on yours.
Sad to say I do not have Navigator 4 and cant really afford to get it to make use of the above software, I need to find a cheap place that sells it although thats hard to find.  |
bobgentry Occasional Visitor
Posted: Fri Jun 03, 2005 10:58 am Post subject: |
Hi I've been in spain the past month playing with my 150 (works great with downloaded maps) so I got a bit behind with the camera database.
I've now converted the speed cameras from 30/05/2005.
This file speedcameras3005.zip can be downloaded from
http://www.active-soccer.co.uk/The%20Medion%20MDPNA%20150.htm.
I have checked the portsmouth cameras they seem to be fine. |
Posted: Fri Jun 03, 2005 11:34 am Post subject: |
Hi Bob
Hope you had a good time in Spain? :D
I have now managed to update my PNA175 to Med NAv 4.4 and have loaded POIWarner on it so all is now well with the cameras etc, I have also updated all the cameras in Portsmouth to reflect the situation on the ground so to speak.
Keep up your good work though.
tel33 |
beighton Occasional Visitor
Posted: Sat Jun 04, 2005 12:58 am Post subject: |
I have just bought my first pocket GPS - the PNA 175 with version 4.4 on and would like to add the camera info.
As a complete novice, can you tell me how I go about obtaining and adding the overlay.
Is it available free or do I have to buy it, if so what do I buy?
It is easy to install, are there any directions written down that I could follow?
I have looked at the POI-Warner site and the others it mentions but at his moment in time it is not clear to me what I have to do.
Can someone help?
Thanks. |
Posted: Sat Jun 04, 2005 10:38 am Post subject: |
Hi there beighton
If you want the speed camera database for v4.4 you will have to get a program called POiWarner (The one you mentioned earlier). Make sure you only download the program that suits your pna Navigator program, in your case Version 4. Also make sure you have an Activesync connection to your pc or else it wont work.
www.navigating.de/Home_en
Once you PAY for that program (Around £19) and it is installed on the PNA175 you can register at the site POIHandler, this costs around £8 which allows you to download the information for a yearly subscription on the speed camera updates, this site also has many other POI's on it, Restaurants etc but you pay the subs only for the cameras.
www.poihandler.com
Once you have paid the subs and set set up your passwords/profile etc on the POIHandler site you then, on the pna175 in the POIWarner program, put in your user name. This then allows you to connect via Activesync to the POIHandler website and sync all the data you need.
It takes a while to suss out how to do it but it comes quickly.
I hope this helps
tel33 |
Posted: Sat Jun 04, 2005 4:13 pm Post subject: |
Thanks tel33.
I am now up and running - and hopefully within the speed limits! :D |
mak_attack Occasional Visitor
Posted: Sat Jun 04, 2005 8:16 pm Post subject: |
hi,
i am very new to the gps market.
aldi in the UK are doing what i believe is the medion gps (tomtom go lookalike ish) for just under £250
its a father's day gift and i have a few questions:
will the speedcamera database work for this system?
will it detect and bleep etc?
how much is the annual cost?
do i have to buy much on top of what i get from the shop?
is it easy for a novice to setup in a few hours?
i am happy that it can guide my dad on his journey BUT it must be able to function as a speed camera detector. just wanted to know if this unit did it.
thanks in advance |
Posted: Fri Jun 10, 2005 6:09 pm Post subject: |
Beighton I am glad to see you have got it working ok and I hope my istructions helped.
Mak_attack, but sorry my pc has been down for a week due to a hard drive problem that caused me to reinstall the whole operating system from scratch, luckily I had a back up, due to this I have only just seen your text.
I did see the unit in Aldis's but did not see what software they were using, I think it was the Medion Nav 4 in which case its yes to all your questions.
If you read further up this post you will see how to get the cameras working from a brief descrition I did for Beighton.
I am sorry again but I am guessing that I am too late in answering your post anyway and I hope you have bought it and had success with it.
Regards
tel33 |
SteadyEddy Occasional Visitor
Posted: Fri Jun 10, 2005 7:34 pm Post subject: |
The Medion in Aldi this week has Navigator 4.75 installed. Will these instructions work with this version?
Thanks |
Posted: Sat Jun 11, 2005 9:46 am Post subject: |
Hi there SteadyEddy
Yes it should work is the answer to your question.
The POIWarner program is for V4 and the new V5 of the Medion Navigator.
Make sure you download and install the correct POIWarner version for the version you have on your PNA or else it wont work.
You could download V5 aswell so if you get an upgrade to your Medion Navigator program to V5 you can then update the POIWarner version too to match it.
Hope this helps.
Regards
tel33 |
pixor Occasional Visitor
Posted: Mon Jun 13, 2005 12:43 pm Post subject: |
I have bought the Aldi Medion unit, and then bought (for about £20) the POI Warner software to put on the speed cameras. There is no subscription required, the speed camera database is free from here. All is working well, and I am very impressed with it. |
shaunokeefe Occasional Visitor
Joined: Jun 08, 2005 Posts: 51 Location: Nottingham, UK
Posted: Mon Jun 13, 2005 1:53 pm Post subject: |
Yea i got the same setup,
The aldi unit and POIWarner with the speed camera's on.
Only crap thing is when your in 3d mode none of the symbols show up apart fromt he built in petrol stations.
Shaun |
Shaun |
flea Occasional Visitor
Posted: Wed Sep 07, 2005 3:10 pm Post subject: All Users of Medion MDPNA 100 |
did it work on the 100?? And how do you do it??
lancscpl2004 wrote: | will this work with the mdpna 100 by any chance?, if not, has anyone else got the camera database for the mdpna 100 as the ones on this site only seem to work with the TTN Navigator |
Posted: Wed Sep 07, 2005 3:13 pm Post subject: Medion 100 |
Bobgentry
Do you know if it works on the MDPNA100 as well as the 175?? |
