Pocket GPS World :: View topic - TTN 3, all data reset so it looked like a clean install?
otguk
PostPosted: Tue May 31, 2005 7:06 pm    Post subject: TTN 3, all data reset so it looked like a clean install? Reply with quote
Hi, 1st post.
Had TTN 3 for about 18months, all running ok.
Until today when I turned it on when its asking me to agree to the terms and conditions of a 1st install?
So I click on yes and look in recent locations only to be told it empty? Tell it to nav home and get told that home location is not set!
So were has all the data gone? If its still there how can I get TTN3 to see it.
Would an ActiveSync work?
Ideas. Anything you need to no, ask plz.
Thanks.
PostPosted: Tue May 31, 2005 8:14 pm    Post subject: Reply with quote
sounds like the CFG file got corrupted - possibly when you switched the device off while TomTom was still running.
Next time make regular backups of the CFG file.
otguk
PostPosted: Wed Jun 01, 2005 7:48 am    Post subject: Reply with quote
OK ta,
Does it not back that file up itself say every month and hide it? Pitty its not part of the program. Well I have learned the hard way.
Thanks.
oddsock
PostPosted: Wed Jun 01, 2005 8:39 am    Post subject: Reply with quote
otguk wrote:
OK ta,
Thanks.
Hi, sorry about your mishap its happened to me a couple of times Sad If you buy Sprite Backup that should be an end to any problems you may have in the future as you can set it up to backup automatically If you read through these board you will see tha it a must have piece of software! If you have an ipaq you may be able to buy at a discount ,mine cost $10
otguk
PostPosted: Wed Jun 01, 2005 8:52 pm    Post subject: Reply with quote
Ta,
Will do some searching.
Thanks again ppl.
beermatt
PostPosted: Thu Jun 02, 2005 2:25 pm    Post subject: Reply with quote
I've had this happen a few times - in my case it seems to be occasionally when I connect via ActiveSync the cfg file(s) are deleted 8O
Anyway, whenever this has happened I've always found a fairly recent version of the cfg files in the recycle bin on my PC - drag them back to the PocketPC and everything is back to normal..
