Steve-TT Occasional Visitor
Posted: Tue May 24, 2005 8:21 pm Post subject: Navman Pin SmartSt V3 Help plz |
Hi i own i Navman Pin Mio Digi walker having today upgraded from Version 2 to 3 i have tried to import the POI data base i first used the single file, which seems to work ok so no problems there, however it seems very limited as it does not indicate what type of camera or speed.
Is there away with this model/software that I can use all the data bases that indicate speed in the area or whether its a traffic light camera/redlight, i would like to use zoned csv files or i can my machine only use the single file as this is only giving me notice that there is a camera and not telling me much else.
Lastly is there any sites that have good wav files for audibal indications as i only get a bleeping and the wav files that come with the files dont sound to good when it says gatso.
Many thanks
Steve |
Posted: Tue May 24, 2005 8:30 pm Post subject: Re: Navman Pin SmartSt V3 Help plz |
Steve-TT wrote: | Hi i own i Navman Pin Mio Digi walker having today upgraded from Version 2 to 3 i have tried to import the POI data base i first used the single file, which seems to work ok so no problems there, however it seems very limited as it does not indicate what type of camera or speed.
I seem to a csv folder, and then a zoned csv folder and also single file and could someone explain the difference or point me in the right direction to info as i can only use the single file.
Many thanks
Steve |
Posted: Tue May 24, 2005 8:31 pm Post subject: Re: Navman Pin SmartSt V3 Help plz |
Many thanks
Steve |
icsys Frequent Visitor
![](http://www.getoutguide.pwp.blueyonder.co.uk/screenshot/Animation3.gif)
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Tue May 24, 2005 8:33 pm Post subject: |
Hi, welcome to the forums.
Yes you can use the individual files.
Using the POI Editor, import each of the .csv files after converting them.
pocketgps_uk_gatso_20.csv to pocketgps_uk_gatso_70.csv
pocketgps_uk_mobile_20.csv to pocketgps_uk_mobile_70.csv
pocketgps_uk_specs.csv
pocketgps_uk_temp.csv
pocketgps_uk_redlight.csv
Rremember to use the different .bmp icons for each file or they will still all look the same.
Also note that whatever sound you choose (you can use any .wav file as long as you name it cosmicle.wav) you will get the same sound warning for all of them. _________________ Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
Posted: Tue May 24, 2005 8:55 pm Post subject: Re: Navman Pin SmartSt V3 Help plz |
Ignore this |
Posted: Tue May 24, 2005 8:56 pm Post subject: Re: Navman Pin SmartSt V3 Help plz |
Is there anywhere that lists which files i need to use for the above machine, i cant understand the difference between them etc, i wish to use all the gatso so they indicate the speed in that area etc.
Thanks All |
Posted: Wed May 25, 2005 12:27 am Post subject: |
The files you will require are:
In the 'speed zoned' folder, 'Gatso'' > 'csv files': use all the files.
If you want all the other cameras:
In the 'speed zoned' folder, 'Mobile' > 'csv files': use all the files.
From the 'csv files' folder use:
pocketgps_uk_specs.csv - pocketgps_uk_temp.csv - pocketgps_uk_redlight.csv
Just remember to use the .csv files for Navman software and the .bmp file of the same name. The .bmp icons are in the 'ov2 bmp files' folder but ignore the .ov2 files. Or use the icons in the 'alternative bmp files' folder.
You can ignore all the rest.
(Confused? I know what they all are and it confuses me too !!) _________________ Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
Posted: Wed May 25, 2005 12:36 am Post subject: |
You can read an explanation of the database and how it is made up here.
If your still confused after reading it PM me. _________________ Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
