Pocket GPS World :: View topic - Satalite connection time.
Rob588
PostPosted: Sun May 22, 2005 7:19 pm    Post subject: Satalite connection time. Reply with quote
My Pharos GPS has suddenly started taking about 5-10 minutes to get a signal. Would there be a reason for this as I have never had a problem before.
HP 2210
Tom Tom 3.07
Pharos GPS
PostPosted: Sun May 22, 2005 9:52 pm    Post subject: Reply with quote
The little backup battery may have died, forcing the receiver to re-load the base data every time it's switched on basically a cold start). If that's the case then there's not much you can do - those batteries are not replaceable.
Rob588
PostPosted: Sun May 22, 2005 10:23 pm    Post subject: Reply with quote
Thanks for the reply.
It does seem to have slowed down since the GPS has been connected to the CF slot rather than working from the battery in the GPS device via the bluetooth connection, could that be it??????
The GPS has a built in battery, but when you connect it to the CF slot you remove the battery, could that be the problem????
Cheers.
PostPosted: Mon May 23, 2005 12:16 am    Post subject: Reply with quote
No, that's a different battery. I am talking about the tiny backup battery on the PCB of each receiver. Pretty much like the battery that keeps your computer's clock and BIOS configuration when the computer is switched off. It's not related to the main battery of the BT sleeve.
novaya_zemla
PostPosted: Mon May 23, 2005 1:21 pm    Post subject: Reply with quote
Check you have the correct time set.... It needs to know where those sats are after all and if you have the wrong time it thinks they are somewhere else! :D
novaya_zemla
PostPosted: Mon May 23, 2005 5:21 pm    Post subject: Reply with quote
On reflection that's probably complete tosh....
PostPosted: Mon May 23, 2005 5:30 pm    Post subject: Reply with quote
not entirely. The receiver needs the exact time, but it should get that from the sats also after a while.
In AGPS the time comes from the cellular network. Since it travels a shorter distance it's supposed to be more accurate.
22.055 (29 May 24)
