Pocket GPS World :: View topic - Tomtom Go Update 5.10
jimbokb
PostPosted: Sat May 21, 2005 1:55 pm    Post subject: Tomtom Go Update 5.10 Reply with quote
I have been informed by email that an update from v 5.0 to v 5.10 is available for the Tomtom Go range.
I have already read that someone has had locking up problems after installing this update.
Has anybody else had this problem or even installed with no problems.
Apparently there is an increase in route plotting of about 20%.
PostPosted: Sat May 21, 2005 3:14 pm    Post subject: Reply with quote
I had no problems in going from 5.0 to 5.2 and it's in the speed of computing the route that seems to be 20-30% faster. It searches POI's quicker also.
rkm_hm
PostPosted: Sat May 21, 2005 4:43 pm    Post subject: Reply with quote
Oldboy wrote:
I had no problems in going from 5.0 to 5.2 .
I assume you mean 5.1 - unless you know something which we don't? :o
Roger
jimbokb
PostPosted: Sat May 21, 2005 4:53 pm    Post subject: RE: Go Update Reply with quote
Sorry for any confusion about the update, but on the Tomtom site it does call the update 5.10
click link to check
http://www.tomtom.com/support/support.php?ID=3&Language=1
Regards
Jimbo
PostPosted: Sat May 21, 2005 6:01 pm    Post subject: Reply with quote
Roger
My excuse is that I was typing fast, but the Capital Offence is that I didn't check it before posting. 'Embarassed'
jimbokb
PostPosted: Sun May 22, 2005 7:17 pm    Post subject: Tomtom Go Update 5.10 Reply with quote
I have updated my TTG 300 from v5.0 to v5.10, no problems, I have been out and tested it everthing works fine and it does appear that route planing is quiye a bit quicker. I drove around for about an hour everything is ok. Others have reported lockups but this appears to only affect TTG Clasic.
I have a friend who has one and he had to revert to v 5.0. So do back up your SD card before trying the update.
PostPosted: Sun May 22, 2005 9:38 pm    Post subject: Reply with quote
The users who have had problems with the Classic seem mostly to have only 128Mb SD card.
AshleyHinton
PostPosted: Tue May 24, 2005 12:57 pm    Post subject: Reply with quote
I have a classic and have had no problems (so far) with V5.10
It has been suggested (in another forum?) that lack of free space on the SD card could be an issue.
I have on original 128MB card:
UK Map (version which shipped with my Classic TTG)
Revenue (sorry, "safety") camera POI's
V5.10 software.
Some extra POI's (supermarkets, mc donalds, etc)
Cusomised startup screen file (not very big in filesize)
All that little lot comes to 107MB, whcih leaves me with 21MB (aprox) free.
I don't know if there is a recommended free space which should be allowed on the SD card - I should imagine and hope though, even if true, that it would be a lot less than 21MB
I'm assuming it would be for some kind of 'virtual' memory, swap space, paging space or whatever..??
Ashley
biggy7
PostPosted: Tue May 24, 2005 1:37 pm    Post subject: Reply with quote
hi guys
i have TomTom Go classic, and im looking to update to v5.10, it has 4.40 on there already.
do you think it will be wise to update? i wont lose any info will i?
i have made a backup of my SD card (128mb)
so is it just a matter of downloading the update and installing?
would i need to install v5.0 first then v5.10? or can i just go straight to v5.10
cheers!
PostPosted: Tue May 24, 2005 6:11 pm    Post subject: Reply with quote
The upgrade is good, and all your favourites are safe. If you have the spoken camera alerts you will need to download the new version for 5.1.
Yes.
No, just go straight for 5.10.
spiremans
PostPosted: Tue May 24, 2005 8:49 pm    Post subject: tom tom 300 update 5.10 problem Reply with quote
having read though the posts in this thread wonder if someone could help me . I have tried to update my tomtom 300 with the 5.10 update as advised i made a back up of my sd card , the backup i made already had the speed camera poi on (i didnt make a backup of original settings before adding speed cameras), i have a 128MB sd card when i tried to update my tomtom updated or i thought it had until i tried turning it on to which i found it had totally froze up . i had to format sd card and install backup to get it working again , my sd card is showing i have used space of 116mb free space of 2.42 and capacity 119mb is the reason it wouldn't update because i don't have enough memory left on my sd card or could it be the speed camera poi that i downloaded from this site.
any help please would be appreciated
spireman
PostPosted: Tue May 24, 2005 9:19 pm    Post subject: Reply with quote
I would take the camera files off first, or if you have them in the backup copy, just delete them.
Then install the V5.1 upgrade. Check that you have uninstalled all the unused voice direction files, and then copy back the speed camera files.
Note that if you are using the camera voice file from Pocket GPS you will need to download the new data.chk file for V5.10.
spiremans
PostPosted: Tue May 24, 2005 10:06 pm    Post subject: Reply with quote
cheers m8 did exactly what u said and it updated fine added speed camera data again and it still works fine thank you
what is the voice file i can put on my tom tom as a warning in which folder do i put it read somthing somewere about changing name of fie
thanks again
spireman
PJEvans
PostPosted: Tue May 24, 2005 11:07 pm    Post subject: Reply with quote
http://www.pocketgpsworld.com/tomtom-go-poi-alerts.php
Here's the link for the new alerts, you need to rename the data.chk file on your SD card then name the downloaded file data.chk to get it to work
Make sure you download the one for V5.10
