cyclopops Occasional Visitor
Posted: Mon May 09, 2005 7:44 am Post subject: speedb camera question |
i have the speed camera database (as my previous post says)
but what id like to do is inut a different distance to warn me of a camera presence it currently has 50, 100, 400, 600, 800
but im not quite happy with these distances 50 is almost on top of the camera
100 is not quite far enough and 400 is a little to far
id like to have the option of 200 or 250 on there
how can i get this distance on there??
need help asap |
nunew33 Occasional Visitor
Posted: Tue May 10, 2005 4:39 pm Post subject: |
help asap?
Try slowing down |
Joined: 30/12/2002 17:36:20 Posts: 4921 Location: Oxfordshire, England, UK
Posted: Tue May 10, 2005 4:58 pm Post subject: |
nunew33 wrote: | Try slowing down |
Not a particularly helpful comment there, nunew33, especially without any smileys. 8O
Cyclopops, I tend to use a distance of 400 metres for all fixed cameras (regardless of speed zone) and 1,000 metres for all mobile sites. That’s on GPSAssist with TTNav3, but the principle is the same for any SatNav using our camera database.
Garmin Camper 770 LMT-D |
Posted: Tue May 10, 2005 4:59 pm Post subject: |
Sorry, smiley intended :D |
Posted: Tue May 10, 2005 5:54 pm Post subject: |
nunew33 wrote: | help asap?
Try slowing down |
ok hows this for starters, i am a driving instructor so by that i dont speed anyway but my wife tends to stray over the limit so it is primarily for her use the camera detection
so is there a way to make the distances i mentioned?? |
Posted: Tue May 10, 2005 10:06 pm Post subject: |
if there is part of the solution will be to understand and mess around with
\\device\Desitinator Aps\Destinator\Common\Interface\Voice\All\DestinatorVoiceManeuvers.inf
Im guessing the distances are fixed seeing as there is no indication of a keyword for distance other than those in the alert distance drop down. |
Posted: Wed May 11, 2005 1:45 pm Post subject: |
Right this file does the drop down menu: DestinatorMSG.inf
look for IDS_DYNPOI_ALERTED_DISTANCES
I added 200 to list buty Setting the menu to this by itself does nothing
I tried adding these two lines to DestinatorVoiceManeuvers.inf
::MW,POI_ALERT_1*200,0,0,150,100;UNITS,"Poi Alert 1"
and
::MW,POI_ALERT_1*THIRD_DISTANCE,0,0,151,100;UNITS,"Poi Alert 1" as we know that third distance is 200.
Neither worked. I set first distance to 200 then second to 50. Only got 50 warnings. Ive trawled through the other files cant find anything else
Didnt try DISTANCE_TYPE_200, maye ill try that tonight and see what happens!! |
ReZ Occasional Visitor
Posted: Thu May 19, 2005 9:48 pm Post subject: |
any luck ? |
steve404 Occasional Visitor
Joined: Apr 13, 2005 Posts: 45 Location: The North of Wales
Posted: Fri May 20, 2005 1:54 pm Post subject: Safety cameras and things |
Guys,
I am quite interested in this too, I have successfully downloaded the camera indicators onto my Acer N35, but, I am almost on top or have passed the camera before I am told I think 'Favourites one', is that correct, if so have we come to a final decision on if we can change distances to cameras?
Secondly is it me or does the delightful woman say 'ird' exit at roundabouts, I dont hear the 'th' at the beginning.
Good kit though........
Steve. |
Posted: Tue May 24, 2005 4:31 pm Post subject: |
No luck. Although you can change the menu options they have obviously hard coded it. It simply ignores any other value.
Its a bit bizarre in that it wouldnt take that much to have a completely customisable warn distance within a specified range as long as you recorded the appropriate wav file to go with it.
Im not geeky to try anything else.
Regarding womans voice, that was the first thing to go. My 5 year old son now provides me with all the directions. Its incredibly easy to record your own directions. Took me 30 minutes with a 5 year old who wouldnt say things first time so should take 10 minutes for anyone else.
Dalek voice directions to come soon!
Steve 404 you can set the alerts to go off way before being on top of them, are you aware you can set two distances |
Posted: Tue May 24, 2005 8:27 pm Post subject: Cameras |
Nunew,
No I wasnt aware I could set two distances, how do I do that?
Steve |
Posted: Thu May 26, 2005 6:58 am Post subject: |
Hit destinate button
Then favourites
Highlight Auto Alert 1 or 2 (as in make sure it has the blue highlight not jst a ticked box)
click on tools
select edit
hey presto- you can choose 2 warnings, same wav file though
As a matter of interest I cant get POI to work
You are supposed to see POIs on your map if check boxes ticked.
Does this work for you? |
