needhelp Occasional Visitor
Posted: Thu Apr 28, 2005 1:07 pm Post subject: tomtom 4.40 wont recognise my gps |
I have tomtom 4.40 running on a mdppc250 with a royaltek rgm2000 gps reciever now under tomtom 3 no problems but with 4.4 I just get told that no gps is connected. I have been to configure gps and have set as other cabled gps, baud rate 4800 but thats all the options I'm given it won't even let me choose the com port its on. Now am I right in saying that the rgm 2000 IS a serial gps ?
If so why does it not work?
Reinstalled tomtom 3 last night just to check gps is actually working and it immediately found me so no problem there. |
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Sat Apr 30, 2005 2:51 am Post subject: |
as far as I know you need to use the GPS driver from v4 (also if you want to run v3). I know that for BT receivers that's the case. Not sure if it also affects serial receivers like yours though.
Are you doing a soft reset before you start TTN4 ? Otherwise you may run into a situation where the COM port is still occupied by another program. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sun May 01, 2005 9:10 am Post subject: |
Hi thanks for your reply Yes am doing a soft reset but tomtom just continuasly says no gps device.
There is no option to select the com port in ver 4 is there.
I ask as lookin for answers I saw that by changing the driver to 2.07 you can select other bluetooth devices etc but I still cant c any menus for selecting com port. |
alix776 Pocket GPS Moderator
Posted: Sun May 01, 2005 9:19 am Post subject: |
you have to use the v4 gps driver go into the configuration by tapping the signal strength bar, then the same in the next screen and select other bluetooth gps and set the baud rate to 34800 tap select make sure receive all in coming beams is unchecked _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun May 01, 2005 11:14 pm Post subject: |
have tried that but tapping other bluetooth device only tells me to pair both devices I click on ok then it goes back to the gps screen saying no gps device.? |
midi Occasional Visitor
Posted: Sun May 15, 2005 2:51 pm Post subject: |
I have currently the same problem with TTN4.4.
Did you get a solution ?
midi |
