Pocket GPS World :: View topic - safety camera softwear
Ama
PostPosted: Fri Apr 29, 2005 6:05 pm    Post subject: safety camera softwear Reply with quote
Hi im new to tomtom can any one give me a link to the latest safety camera softwear . ive got a tomtom 300 . and maybe tell me how to install it ? thx Daren
DavidW
PostPosted: Fri Apr 29, 2005 6:27 pm    Post subject: Reply with quote
It should be the same instructions as the original Go - you use the POI warning feature that's built into Go.
Ama
PostPosted: Fri Apr 29, 2005 6:34 pm    Post subject: Reply with quote
do you have link for softwear?
DavidW
PostPosted: Fri Apr 29, 2005 6:36 pm    Post subject: Reply with quote
You don't need any - as the Database page says:
Copy the OV2 and BMP files to your Storage Card into the Country Directory (e.g. \Great Britain) and enable them in the POI screen.
Ama
PostPosted: Fri Apr 29, 2005 7:13 pm    Post subject: Reply with quote
how do i connect tomtom 2 pc? ive plugged in the usb but nothing happens'/ i cant install a driver or nothing HELP :P
Wonderwall
PostPosted: Fri Apr 29, 2005 7:17 pm    Post subject: Reply with quote
You have the disk in right???
Ama
PostPosted: Fri Apr 29, 2005 7:33 pm    Post subject: Reply with quote
yes disk is in but cable dont seem to wana pick up
PostPosted: Fri Apr 29, 2005 8:44 pm    Post subject: Reply with quote
Which windows version are you using?
Ama
PostPosted: Fri Apr 29, 2005 9:36 pm    Post subject: Reply with quote
xp sp 2
kevw
PostPosted: Sat Apr 30, 2005 12:18 am    Post subject: Reply with quote
make sure TTG is turned on - i seem to remember reading there is a new power off function when connecting by USB Wink
PostPosted: Sat Apr 30, 2005 8:32 am    Post subject: Reply with quote
If TTG sits idle for several minutes it will switch off.
Ama.
Have you tried plugging into another USB port?
Is it possible to try another USB lead, or use the USB lead on another device (camera perhaps)?
meditek
PostPosted: Sat Apr 30, 2005 10:51 pm    Post subject: Reply with quote
Don't worry you're not the only one. I've read you need the (non-existent) power supply for it to work reliably. I gave up and used my card reader instead.
Eldar
PostPosted: Sat Apr 30, 2005 11:14 pm    Post subject: Reply with quote
I'm not sure that is correct. Mine connects via USB with no external power or any problems at all. If it doesn't connect straight away, turn the unit on, wait for the application to start and then connect the USB cable.
PostPosted: Sun May 01, 2005 7:44 am    Post subject: Reply with quote
I've never used the mains power lead for connecting to PC, for anything other than experimenting. The internal battery, if fully charged, lasts several hours. Plenty of time to copy, paste or install.
bmwman
PostPosted: Sun May 01, 2005 8:20 am    Post subject: Reply with quote
My process has been to leave the TTG switched off, plug in the cable, then turn the device on.
The device recognises that it's connected and gives a screen showing a picture showing the back of the TTG, and the PC detects the device and shows it as a disk drive in Windows Explorer.
Rich
23.054 (28 May 25)
