Pocket GPS World :: View topic - whats the easy/best speed camera software to use ???
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navigon Handhelds
clivey
PostPosted: Wed Apr 13, 2005 1:30 pm    Post subject: whats the easy/best speed camera software to use ??? Reply with quote
hi, need some help just got a transonic pna with navigon 4, what is the easiest/best speed camera software to use ??
also how do you install it to work with navigon ??
thanks..
Pocketgps
PostPosted: Wed Apr 13, 2005 3:18 pm    Post subject: Re: whats the easy/best speed camera software to use ??? Reply with quote
thanks..
You can normally only use POI-Warner for Navigon GPS software, not sure if there is a version for your system, I would contact POI-Warner to check first as this is not a free utility.
http://www.navigating.de/Home_en/index.htm
Just use there Contact tab top right on web site.
geoslyne
PostPosted: Tue Apr 19, 2005 8:27 pm    Post subject: Reply with quote
Hi Clivey
You need to load and register POI Warner for which there is a one-off payment of just under 30 euros. Next you need to register with POI Handler making sure you sychronize account to POI Warner. The PNA should be switched on and connected to activesync to you main computer whilst doing this.
Once done you will be able to download directly to the pna using synchronisation which is very easy.
UK Camera data is not free and cost around 12 euros per year to use although there are 1000's of POI's which are free. I currently have around 40000 poi's on my Transonic, so there's plenty of room on board.
Hope this helps.
Geoslyne
clivey
PostPosted: Wed Apr 20, 2005 11:08 am    Post subject: Reply with quote
what websites do i need to go on, have you got the address..
thanks
clive
geoslyne
PostPosted: Wed Apr 20, 2005 8:17 pm    Post subject: Reply with quote
Hi Clive.
Poi Warner is on
www.navigating.de/MN4_EN/POI/Bestellen/Bestellen.htm
which gets the Navigon software you need.
Poi handler is www.poihandler.com
if you synchronise this to POI Warner you will be able to download directly
by synchronisation.
Make sure your Pna is switched on and connected via activesync to your desktop.
Hope this works for you
Geoslyne.
Pocketgps
PostPosted: Wed Apr 20, 2005 10:17 pm    Post subject: Reply with quote
The UK Safety Camera data can be downloaded from this web site and is FREE.
bobgarb
PostPosted: Tue Apr 18, 2006 10:09 am    Post subject: Navigon PNA Reply with quote
but off topic but the new camera I submited at farley road croydon, which is near selsdon Surrey as now been fully Installed and I think is now active!
Regards, Bob
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navigon Handhelds All times are GMT + 1 Hour
