clivey Occasional Visitor
Posted: Wed Apr 13, 2005 1:30 pm Post subject: whats the easy/best speed camera software to use ??? |
hi, need some help just got a transonic pna with navigon 4, what is the easiest/best speed camera software to use ??
also how do you install it to work with navigon ??
thanks.. |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Wed Apr 13, 2005 3:18 pm Post subject: Re: whats the easy/best speed camera software to use ??? |
clivey wrote: | hi, need some help just got a transonic pna with navigon 4, what is the easiest/best speed camera software to use ??
thanks.. |
You can normally only use POI-Warner for Navigon GPS software, not sure if there is a version for your system, I would contact POI-Warner to check first as this is not a free utility.
http://www.navigating.de/Home_en/index.htm
Just use there Contact tab top right on web site. |
geoslyne Occasional Visitor
Posted: Tue Apr 19, 2005 8:27 pm Post subject: |
Hi Clivey
You need to load and register POI Warner for which there is a one-off payment of just under 30 euros. Next you need to register with POI Handler making sure you sychronize account to POI Warner. The PNA should be switched on and connected to activesync to you main computer whilst doing this.
Once done you will be able to download directly to the pna using synchronisation which is very easy.
UK Camera data is not free and cost around 12 euros per year to use although there are 1000's of POI's which are free. I currently have around 40000 poi's on my Transonic, so there's plenty of room on board.
Hope this helps.
Geoslyne |
Posted: Wed Apr 20, 2005 11:08 am Post subject: |
what websites do i need to go on, have you got the address..
thanks
clive |
Posted: Wed Apr 20, 2005 8:17 pm Post subject: |
Hi Clive.
Poi Warner is on
www.navigating.de/MN4_EN/POI/Bestellen/Bestellen.htm
which gets the Navigon software you need.
Poi handler is www.poihandler.com
if you synchronise this to POI Warner you will be able to download directly
by synchronisation.
Make sure your Pna is switched on and connected via activesync to your desktop.
Hope this works for you
Geoslyne. |
Posted: Wed Apr 20, 2005 10:17 pm Post subject: |
The UK Safety Camera data can be downloaded from this web site and is FREE. |
bobgarb Occasional Visitor
Posted: Tue Apr 18, 2006 10:09 am Post subject: Navigon PNA |
but off topic but the new camera I submited at farley road croydon, which is near selsdon Surrey as now been fully Installed and I think is now active!
Regards, Bob |
