oli1983uk Occasional Visitor
Posted: Thu Mar 31, 2005 5:46 pm Post subject: TT3 on a hp jornada 928 |
I have a hp jornada 928 running pocket windows 2002, i have seen on a couple of sites that tom tom 3 will work on this handheld but also some say it will not work. so does anyone here know if it will work or not? cheers for any help |
jwl Occasional Visitor
Posted: Thu Mar 31, 2005 5:48 pm Post subject: |
Also does anyone know if it is possible to upgrade the windows 2002 on this to the 2003?
Or if it is worth doing.
Thanks |
alix776 Pocket GPS Moderator
Posted: Fri Apr 01, 2005 2:28 am Post subject: |
it szhould run ok on the 928 youll need a wired receiver and a cf card to get it to quicker disable show poi on map in the poi properties screen as for upgrade to 2003 sorry you cant the jornada was replaced by the ipaq as a product line _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
mentalpostie Occasional Visitor
Posted: Fri Apr 15, 2005 2:50 pm Post subject: |
i can tell you 100% that it does work as i've had nav 3 running perfectly on mine for over 12mths now just hoping that nav 5 will be ok
but you do have to have a wired system and get a decent sized CF card for the maps i've found it best to install the main nav program into the actual memory of the 928 and then the maps and any addons onto the CF card |
Darren Frequent Visitor
Posted: Fri Apr 15, 2005 3:05 pm Post subject: |
TomTom 3 will be the last version to support the SH3 processor used in the Jornada's. Version 5 only supports ARM processors.
There is no upgrade path to 2003/2003SE for your device nor will there be ![Sad](modules/Forums/images/smiles/icon_sad.gif) _________________ Darren Griffin |
Posted: Sat Apr 16, 2005 9:11 pm Post subject: |
according to my jornada it use's the arm processor not sh3 were there different versions made of this pda then |
