Pocket GPS World :: View topic - Mains charger for GPS?
mij
PostPosted: Thu Apr 14, 2005 12:43 pm    Post subject: Mains charger for GPS? Reply with quote
Hi, first I want to say thank you for all the help this site has provided and for steering me towards the free SDA+Copilot from Fonehouse at Bluewater.
What I would like to know is what mains charger can I use to charge the CoPilot BT GPS? As it only comes with a cigarette charger for the car. Also is it possible to change the battery if the need arises?
mij
mij
PostPosted: Thu Apr 14, 2005 1:07 pm    Post subject: Reply with quote
I looked to edit the original post and could not see the edit function.
I also wondered if the battery goes flat on the smartphone does it lose all it's settings like the iPAQ? as it does not have a backup programme I am a bit concerned.
mij
PostPosted: Sat Apr 16, 2005 7:13 pm    Post subject: Reply with quote
You can use any PDA charger that uses the 5vdc 2amps. A HP/Compaq iPAQ charger will suffice.
Not sure about the SDA but I believe it will wipe the memory, although I don't have one to test it.
PostPosted: Sat Apr 16, 2005 7:25 pm    Post subject: Reply with quote
The SDA stores its settings in non-volatile memory so a flat battery will not result in lost data.
As for the charger, the easiest thing is to buy a 240v cigarette lighter adapter, these plug into the wall socket and have a cigarette lighter socket into which you can plug the cigarette lighter lead.
See here for an example, scroll down to 'Mobile Phone Car Charger to Mains Charger Converter'.
The CoPilot BT GPS does not have a user replaceable battery.
mij
PostPosted: Sat Apr 16, 2005 8:32 pm    Post subject: Reply with quote
I have an iPaq and the charger worked fine.
mij
mij
PostPosted: Sun Apr 17, 2005 9:04 am    Post subject: Reply with quote
Hi again,
Hope you dont mind one more question?
I setup my iPAQ 2210 & TT3 with the CoPilot BT GPS following instructions from this site, everything works OK untill I start driving and the map screen freezes.
I have the maps on a "VIKING INTERWORKS SD 256MB JAPAN" is this the problem? and would getting a compactflash card cure this?
If a compactflash card is the solution can you recommend any.
Thank again
mij
PostPosted: Sun Apr 17, 2005 9:21 am    Post subject: Reply with quote
SD is the problem, replace this with CF for map storage and you'll be sorted.
Any CF card will be fine, make and speed are much less of an issue with CF.
mij
PostPosted: Sun Apr 17, 2005 10:06 am    Post subject: Reply with quote
Thanks again, off to Ebuyer to get a CF.
Great site
mij
