sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Sun Jan 22, 2017 10:44 am Post subject: Garmin DEM map |
For anyone who has lost the DEM map it's now available from http://www.garminservice.de/downloads/basemap/DEM/gmapdem.img
Note this is only aimed at those models that previously had a DEM map which a map update has removed. It may or may not work on other models.
In all cases it needs to be placed in the hidden .system folder. _________________ Where there's a will ... there's a way. |
Kremmen Pocket GPS Verifier
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Sun Jan 22, 2017 11:59 am Post subject: |
I've grabbed it so I can put it on DropBox alongside the Converter.
Just in case they pull it. _________________ Satnav:
Car Average MPG :
MichaelCahill Regular Visitor
Posted: Sun Jan 22, 2017 3:47 pm Post subject: |
When I download and try to open, it tells me that the disc image file is corrupted.
Any idea what this might mean? |
pcaouolte Frequent Visitor
![](modules/Forums/images/avatars/1614640253476fea0f01bba.jpg)
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Sun Jan 22, 2017 3:56 pm Post subject: |
It should be placed in the .system file on the Garmin device. It can't be opened using a PC. _________________ Paul |
Posted: Sun Jan 22, 2017 4:05 pm Post subject: |
Plus, you will need to temporarily enable Windows hidden and system files to see where it needs to go.
The same procedure as you 'should' be doing to perform a complete device backup when you first get it. _________________ Satnav:
Car Average MPG :
Posted: Sun Jan 22, 2017 4:08 pm Post subject: |
Definitely worked here so should be fine ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) _________________ Where there's a will ... there's a way. |
M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Sun Jan 22, 2017 4:41 pm Post subject: |
And in answer to the question "Does it work on a 2569 or 2699?" the answer is No. |
BAVC10 Lifetime Member
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Posted: Sun Jan 29, 2017 12:20 pm Post subject: |
Whilst not linked to the missing DEM files has anyone noticed that Garmin has moved away from the Worldwide AutoRoute DEM Basemap NR5.01 provided by the National Oceanic and Atmospheric Administration?
They've used this for many years but the latest DRiveLuxe50 I purchased now uses Basemap NR2.00 instead of the file mentioned above (yet an earlier DriveLuxe50 has NR5.01).
Somewhat confusingly, two 'newer' (manufacturing dates) Drive50 World Traveller editions still use the NR5.01 file.
Anyone able to shed any light on the changes. _________________ DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3 |
