Pocket GPS World :: View topic - Screen Capture
Screen Capture
Mally1957
PostPosted: Wed May 18, 2011 8:24 pm    Post subject: Screen Capture Reply with quote
Does anyone know if this still works on the latest software version.
Had the folder named screen in the root of the directory with a blank file within named capture.
I have checked it is named just capture and not with an extension .txt or .doc or similar.
Have not used for a while but when I come to use it tonight it just starts the map zoom.
Device and application details as per sig below, thanks for any info.
Malcolm
A now retired Tomtom 940 v9.541.3145439.1 OS:1493118, GPS v1.20 Boot 5.5120, West Europe Map v1025.9386
dhn
PostPosted: Wed May 18, 2011 8:43 pm    Post subject: Reply with quote
Try putting your thumb (or finger) on the left side of the screen but at the middle, not the top. Then, slide your finger up to the top and see if that helps.
Mally1957
PostPosted: Wed May 18, 2011 9:00 pm    Post subject: Reply with quote
Thanks for the quick reply David, have given that a go but no luck there Sad
Malcolm
Oldboy
PostPosted: Wed May 18, 2011 9:32 pm    Post subject: Reply with quote
Does the Folder Screen have an Upper Case 'S'?
Does the File capture have a Lower Case 'c'?
PostPosted: Wed May 18, 2011 9:39 pm    Post subject: Reply with quote
It still works on my GO550 - App 9.058, names "Screen" and "capture" as per Oldboy's post. I can't remember how it behaved as I haven't used it for a while - testing it now takes a fairly long press top left corner (not a tap).
Mally1957
PostPosted: Wed May 18, 2011 9:52 pm    Post subject: Reply with quote
Richard / Dennis
I do have a replacement 940 from tomtom that I installed it on.
Can confirm I had screen and capture both all lower case and thanks to your posts I have renamed the folder Screen but unfortunatly still no luck even with the long press rather than the tap which is how I remember it behaved before.
Malcolm
PostPosted: Wed May 18, 2011 10:10 pm    Post subject: Reply with quote
I'd suggest two things. I can't think of any reason for it not to work if you've got it right, so......
First, recreate it. You've got the folder right (assuming it's in the root of the device). Create a new blank file using Notepad and save it as capture, then delete the extension. Copy/Paste it into the Screen folder.
Then do a reset on the device - I never had one so I don't know whether it has a reset hole to poke or long hold down of the power button.
PostPosted: Thu May 19, 2011 12:19 am    Post subject: Reply with quote
Red herring, I'm afraid...
My "screen" folder has always had a small "s" and it has always worked fine.
Clutching at straws... I know you've said you've done this but do you definitely have Windows set to show all file extensions? Check the root directory... are you seeing "antitheft.bmp" and "data.chk" etc. and not just "antitheft" and "data"?
"Settling in nicely" ;-)
Mally1957
PostPosted: Thu May 19, 2011 4:20 pm    Post subject: Reply with quote
Andy
Many thanks and to you all, you have cracked it.
I have just discovered when I set this up I was using another computer that was not set to show all file extensions.
Goes away and hangs head in shame Embarassed Embarassed Embarassed
Malcolm
