Pocket GPS World :: View topic - What does all this map info mean
cwog
PostPosted: Sun Sep 19, 2010 8:42 pm    Post subject: What does all this map info mean Reply with quote
I have a Nuvi 775T with a Lifetime subscription for both North America and European Maps.
Looking at the Map Info screen in the Satnav it has the following
CN North America NT 2011.20 3D
[1] CN North America NT 2011.20 US & Canada 3D
[2] CN Europe NT2011.20 3D
CN Europe NT 2011.10
[1] Southampton, England, Reading, England
[1] US & Canada
CN Europe NT 2011.20
[1] All
All of the check boxes are ticked.
I am missing something or do I have too much installed, what does the Southampton bit imply - when I downloaded and installed the latest set of NA and European maps I had the map installed on the laptop so I can do a reinstall if necessary.
Thanks for any information on what the above information implies.
PhilHornby
PostPosted: Mon Sep 20, 2010 12:00 am    Post subject: Re: What does all this map info mean Reply with quote
As you've noted, there's nothing to be gained by having the (older) "Southampton,Reading" map, as the area is already covered by the (newer) "CN Europe NT 2011.20 (All)".
My guess is that you'll find a GMAPSUPP.IMG on there that contains the offending data. Try renaming it to something else (eg GMAPSUPP.OLD) and see if Southampton disappears from the list. If it does, you can delete it.
PostPosted: Mon Sep 20, 2010 10:52 am    Post subject: Reply with quote
Perhaps Southampton is the pedestrian mapping?
CN = CityNavigator which are the normal road maps.
PostPosted: Mon Sep 20, 2010 10:57 am    Post subject: Reply with quote
Hmm, having said that, there are no cityXplorer maps for Southampton...
http://www.garmin.com/garmin/cms/cache/offonce/us/maps/cityxplorer/cityxeurope;jsessionid=B216B1258647B73B5B25B0D13CE12D76
Garmin UK are based in Southampton - I wonder if local maps have been added at some point for a demonstration?! Was the device bought new or ex-display etc?
I'd go for Phil's suggestion above!
cwog
PostPosted: Mon Sep 20, 2010 12:28 pm    Post subject: Reply with quote
Thanks for all your comments. The device was bought new a year ago and has all the European maps added /updated under the Lifetime scheme since late last year. The North America maps have been lifetime updated since July time frame.
The Southampton entry appeared after the latest European update came through in August. I downloaded the map and installed it, the new map is visible on the computer using BaseCamp but the reference to Southampton etc does not appear as a selectable map
I followed the suggestion re renaming GMAPSUPP.IMG file to .old and the Soton entry disappeared - so I removed it from the Satnav
I can still see the streets in Southampton and Reading on the map
I kept a copy of the file on the computer just in case it is needed or if I can find a way in Basecamp of looking at it.
Again thanks for your comments
PhilHornby
PostPosted: Tue Sep 21, 2010 9:05 pm    Post subject: Reply with quote
In that case you should also save the GMAPSUPP.UNL file that goes with it.
22.062 (12 Jun 24)
