Pocket GPS World :: View topic - IGO 8.3.2.64029 distance before Speed camera warning
goodstone
PostPosted: Tue Feb 16, 2010 12:49 am    Post subject: IGO 8.3.2.64029 distance before Speed camera warning Reply with quote
Please could someone tell me how to set the distance of voice warnings for speed cameras on the igo.
Been searching for days on forums without an answer. Ideally warning 400 yards before every camera.
I have the voice alerts working but cannot adjust distence control. Do i need a gps fix before changing these?
Many Thanks
linknet
PostPosted: Tue Feb 16, 2010 9:09 am    Post subject: Re: IGO 8.3.2.64029 distance before Speed camera warning Reply with quote
goodstone wrote:
Many Thanks
It's not possible with the standard iGO, some skins will allow you to change this distance but this may not be the best option since iGO dynamically adjusts the distance according to your speed and setting it to a fixed distance disables this.
If you want to experiment then these settings are available via sys.txt:
[warning]
approach_beep_distances=200
approach_beep_sound="!sectionbeepB"
max_section_time=240
overspeed_sound= "!alert3" ; speedcam sound
pedestrian_warning=0
pedestrian_warning_threshold=10
section_beep_distance=200
section_beep_sound= "!sectionbeepA"
section_end_sound= "!sectionend"
section_start_sound="!sectionstartA"
speedcam_maxdistance_from_road=
speedcam_max_angle=20
speedcam_max_lookahead=400
speedcam_snap_distance=200
speedcam_soundtype=1
speedcam_visualtype=1
speedcam_warning=1
speedlimit_warning=1
speedlimit_warning_visual=1
speedlimit_warning_voice=1
speedwarn_alt_builtup_based=1
speedwarn_alt_limit
speedwarn_alt_tolerance
speedwarn_tolerance=110
speedwarn_alt_toltype
speedwarn_toltype
warn_distances=130:450,110:350,90:300,60:200,40:100 ;These numbers are apparently in the format of speed and distance.
Edit: I see that you said "voice warnings" which implies that you are already using a skin since iGO doesn't have voice warnings only beeps.
linknet
PostPosted: Tue Feb 16, 2010 9:21 am    Post subject: Re: IGO 8.3.2.64029 distance before Speed camera warning Reply with quote
warn_distances=130:450,110:350,90:300,60:200,40:10 0 ;These numbers are apparently in the format of speed and distance.
I have done some experimenting with the above values, and they do what they imply. Angles are in degrees, distances are in meters and speeds are in KPH. The 'Warn_distances that I use are rather larger than those shown above
EDIT
'section_beep_distance=200'. Disappointingly, atering this will not give an advanced warning of specs.
goodstone
PostPosted: Tue Feb 16, 2010 12:50 pm    Post subject: Reply with quote
Many Thanks for your help.
Ill play around with sys.txt settings
