Pocket GPS World :: View topic - How do you set up a downloaded walk in reverse on satmap
falconromans
PostPosted: Sat Aug 01, 2009 12:14 pm    Post subject: How do you set up a downloaded walk in reverse on satmap Reply with quote
How do you set up a downloaded walk in reverse on Satmap. we used walk 940 from Walkingworld after loading it onto the Satmap and enjoyed it, now we would like to do it in reverse, i'm not sure, but i believe i read somewhere that you can reverse the walk on the Satmap, can anyone help as we would like to do this with other walks as well, or is that on the Wish list, thanks.
jonesbach
PostPosted: Sat Aug 01, 2009 1:50 pm    Post subject: Reply with quote
Go to-
Main Menu
Select Routes Menu
Select the route
Press Edit
Select Reverse Route
Press Reverse
There is little feedback but if you look at the bottom left of the screen it will say 'Currently Reverse'.
N.B. This is just its state within Satmap, you won't find the route reversed if you export it.
falconromans
PostPosted: Sat Aug 01, 2009 3:40 pm    Post subject: thanks Reply with quote
Thank you Jonesbach, i'm new to Satmap haven't even seen that page before. that's brill i will enjoy using this function. think it would help if we had more graphics so could highlight when reverse in use. Thanks again.
22.055 (29 May 24)
