shambles Occasional Visitor
Posted: Wed May 12, 2004 10:29 am Post subject: Integrate Speed Camera DB with Medion Navigator |
Hi all,
A newbie - so please bare with me. Can anyone tell me how to integrate a Speed camera datase with a medion navigator, running on a medion pocket pc. Just bought one from Halfords - think its fab - and if I can do this - then I will simply be blown away :D
Any help would be graetly appreciated.
regards |
budgie55 Regular Visitor
![](modules/Forums/images/avatars/avatar_ani_013.gif)
Joined: May 10, 2004 Posts: 78 Location: Wigan, United Kingdom
Posted: Wed May 12, 2004 10:40 am Post subject: |
you would need to purchase the POI-Warner addon for MEDION NOT TOMTOM navigator software. Its about €30 whats that about £20 ish.
Then you can install the speed camera POI from here or any where else you can find a camera POI.
See an extract of a previous post of mine on here....
From what is noted on these forums though with the Aldi bundle (if its similar to the old one which I believe it is) then you can use POI-Warner cost about £20-£25 ish for the Medion Navigon software link in my post above.
You can then as I understand it import the camera database and many other POIs in to Warner.
If you wanted to at a later stage you could buy the TomTom navigator software and use other free addons such as POIs using software which is free such as Checkpoint (similar to Warner but FREE) Checkpoint can only be used with TomTom routing software though!! and TomTom will cost you around £100 or more.
From what I read you should find the preinstalled stuff reasonably acceptable for your first PDA. Then again what do I know I'm just a PDA n00b also
this is from thread http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=7863&sid=c6e970548fa0f034af2ee8e49180bc79
Also try doing a search on the forums for warner or poi-warner or alike and do some reading. You will learn far more than I can detail here.
Nope the few pointers ermm point you in the right direction
Best of luck
Allan |
Posted: Wed May 12, 2004 10:57 am Post subject: |
Thanks so much for your help and quick response. It is much appreciated. |
Posted: Wed May 12, 2004 11:10 am Post subject: |
no problem m8 best of luck.
Any other problems post a topic in the beginners lounge or the Navigon forum and someone should pick it up there may even be me if I can help
Allan |
