Westlothian Occasional Visitor
Posted: Wed Dec 31, 2008 10:29 pm Post subject: Profiles |
Is there a good way to let you see the profile of a route?
Experimenting with the Satmap I can only do this by introducing intermediate points manually. It would be useful it a route profile could automatically insert points every 10m for example. |
reklawpete Occasional Visitor
Posted: Thu Jan 01, 2009 11:49 pm Post subject: Profiles |
From the Routes menu select the route you want and press the bottom left button (View). You should then have the route map on the screen and can then again press the bottom left button (Profile) to view the profile. Hope this helps. |
Posted: Fri Jan 02, 2009 12:56 am Post subject: |
Thanks reklawpete,
I can do this, but for a two point route, the profile is only a straight line.
I want to see the profile between the points without adding more manually. |
Posted: Fri Jan 02, 2009 12:57 am Post subject: |
Thanks reklawpete,
