Pocket GPS World :: View topic - Top Gear Routes
Top Gear Routes
electech320ci
PostPosted: Fri Oct 31, 2008 3:01 pm    Post subject: Top Gear Routes Reply with quote
Hi Guys,
I have downloaded from the TomTom site the Top Gear best driving routes, which work ok when viewed through TT and also with Tyre.
However when I try to convert the .itn file to Autoroutes .axe format using ItnConv so that I can view the route offline, Autoroute 2006 will not open it up.
Has anyone got any ideas or do I need to use a different file converter
Oldboy
PostPosted: Fri Oct 31, 2008 7:38 pm    Post subject: Reply with quote
I wasn't aware that any POI conversion programme could convert from .itn to .axe
You could use POIEdit to load the .itn and then save it as a Generic Text File, .asc
Use the Data Import Wizard in Autoroute.
electech320ci
PostPosted: Sun Nov 09, 2008 2:02 pm    Post subject: Reply with quote
Thanks Richard,
What I did in the end was to save the .ITN route as a CSV file using ITNConv then import it into Autoroute using its Data Wizard.
This then showed up on the map as PushPins which I used to calculate and then view the route Very Happy
