Pocket GPS World :: View topic - Is this right for me?
Fatdave42
PostPosted: Sun Sep 14, 2008 8:16 pm    Post subject: Is this right for me? Reply with quote
I am going to scan in 4 A3 os maps for me use. How easy is it to go from one map to another? Can I plan a route on on my PDA? how much of the map will i see on the screen (1:50,000 scale)?
Thanks.
philpugh
PostPosted: Mon Sep 15, 2008 10:12 am    Post subject: Reply with quote
It should be fine.
Being OS maps - it's easy to get accurate calibration - but do make sure that the maps are perfectly flat - you may want to iron them first to get rid of any sharp creases. Of course you are breaking the OS copyright in doing this - but I guess you know this already Laughing
Just a tip I found useful. After scanning - reduce the number of colors to 4 bits (16 colors). It significantly reduces the size of the subsequent map file. Don't bother trying to combine maps - OZiE will chose the next map as you move into it. This means that you don't need to scan large maps all at one time - do them in sensible chunks.
How much you see on your PDA will depend on resolution of screen, zoom level chosen - but it should be adequate for walking/cycling purposes.
You can select maps fairly easily and you can add waypoints etc - so route planning can be done - but to be honest it's much easier to do this on the PC version as you do see much more of the map.
I would download the trials of both products and see how you get on with a small map of an area you know well - so you can check out that your process is correct. The usual gotcha is forgetting to set the datum and projection of the map correctly when calibrating.
Phil
22.062 (12 Jun 24)
