Pocket GPS World :: View topic - How do I reinstall the application on my TT Go ?
cdelecole
PostPosted: Sun Jul 13, 2008 12:42 pm    Post subject: How do I reinstall the application on my TT Go ? Reply with quote
Hi there !
I have formatted my TT Go, and I'd like to reinstall the application.
How do I do that ?
I have launched TT Home, but I can't find the menu to reinstall the application on the device ?!?
dhn
PostPosted: Sun Jul 13, 2008 1:20 pm    Post subject: Reply with quote
Update My Unit and Home should 'see' there is no firmware installed. It will offer to dl and install. Accept it.
cdelecole
PostPosted: Sun Jul 13, 2008 1:33 pm    Post subject: Reply with quote
When I swith it on, it tells a new application has been installed, and the device must be restarted (But the file explorer shows the device is still empty - I have formatted the SD card).
It tells the following procedure :
- Once the application is installed, select "disconnect device" from the device menu
- disconnect the device and switch it on
- reconnect to computer.
In fact, I missed the step to switch the device on when it is disconnected from the computer.
It works now ... except that I see tha pllication version he propose to install is the 6.520
I thought I had version 7 or something before ...
Is 6.520 normal ?
Oldboy
PostPosted: Sun Jul 13, 2008 6:44 pm    Post subject: Reply with quote
Are you using the older Version of HOME?
If so, then now download the latest, HOME2, and when installed it should offer you the V7 software when the device is connected.
cdelecole
PostPosted: Sun Jul 13, 2008 7:39 pm    Post subject: Reply with quote
No ... I'n using HOME 2.
I did try, and it first installs the version 6, once the application is installed, I need to "Update the device" and it foinds version 7.
So that's a 2 steps procedure.
PostPosted: Sun Jul 13, 2008 11:52 pm    Post subject: Reply with quote
If there is no software version on your machine at all, I believe it first looks for any versions already stored on your PC (secretly by Home in it's "download" folder) and installs the latest of those it finds. If you want to FORCE it to re-download the latest version, you have to delete the older versions cached in the downloads folder.
