Pocket GPS World :: View topic - New Garmin Map Update 2008 - City Nav Europe NT - Fault on A
Post new topic   This topic is locked: you cannot edit posts or make replies.    Pocket GPS World Forum Index -> Garmin Portable Navigation Devices
gm4emx
PostPosted: Sun Mar 09, 2008 10:44 am    Post subject: New Garmin Map Update 2008 - City Nav Europe NT - Fault on A Reply with quote
I have a Garmin Street Pilot C510, and have just received my DVD from Garmin for the “Map Update 2008 – City Navigator Europe NT.
This is meant to have all the new maps for each European cluster of countries. UK Ireland, Germany, France, Mediterranean, Alps etc etc.
I activated the DVD on auto run, and loaded the DVD info on to my PC as per instructions, and then went into update by connecting the C510. It did all the software updates and then a drop down menu appears (which one assumes will show all areas). But only the Alps, Spain & Portugal, Nordics, North Eastern Europe.
No UK and Ireland, so I exited the program. When I went to the C510 in stand-alone mode the update-er had installed a new template of all major roads in Europe and whipped all the installed UK & Ireland Info. So no post code search. I can see the UK and all M and A rods and that’s it. No Poi’s for fuel hotels etc that where there before.
So one has to be able to select the countries and load the new data, but the auto run drop down list has all the other European countries missing. By looking at the DVD one can see that UK and Ireland is embedded, but the auto run appears to have a fault be warned.
I ran this DVD on two PC’s both on XP and both with plenty of memory.
Now no active sat nav, and will have to chase Garmin on Monday !!!!!!
Any one else had problems ?
PaulB2005
PostPosted: Sun Mar 09, 2008 11:25 am    Post subject: Reply with quote
As you've also posted this in this thread I'll lock this one. Helps keep all the info in one place and avoids duplicating questions and answers.
Post new topic   This topic is locked: you cannot edit posts or make replies.    Pocket GPS World Forum Index -> Garmin Portable Navigation Devices All times are GMT + 1 Hour
