Pocket GPS World :: View topic - Multiple POI's on Garmin Nuvi 310d
apole
PostPosted: Wed Nov 28, 2007 10:50 am    Post subject: Multiple POI's on Garmin Nuvi 310d Reply with quote
Hi there,
Apologies if this is a daft question but is it possible to have multiple POI's on my unit, loaded via the POILoader program.
Last year I tried to have french and UK speed cameras and I found that you could have one or the other, not both.
I'm looking to have UK speed cameras, and a couple more such as LPG filling stations etc. Is this possible?
Many thanks.
Andy
philpugh
PostPosted: Wed Nov 28, 2007 12:20 pm    Post subject: Reply with quote
Yes you can.
You just need to bear in mind the fact that everytime you run POILoader to load POIs - it replaces the existing POI file on your unit. So... Keep ALL the POIs you want in a folder on your PC. Storing them in separate sub-directories will create different categories (e.g. ATMs, Post Offices...) which make it a bit easier to find and manage on the unit.
Phil
inspiredron
PostPosted: Wed Nov 28, 2007 6:58 pm    Post subject: Reply with quote
As Philpugh says put the different categories of POI in different directories and sub directories to make navigation of them on the unit easier. But if you want UK and foreign speed cameras you will want a mix of mph and kph which can't be done in one POI file. See
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=57496 this post for the way to do it.
apole
PostPosted: Wed Nov 28, 2007 8:38 pm    Post subject: Reply with quote
Thanks guys, will give the url above a go.
22.055 (29 May 24)
