Pocket GPS World :: View topic - help please making a diversity aerial
dany_boy
PostPosted: Mon Mar 17, 2008 10:56 pm    Post subject: help please making a diversity aerial Reply with quote
hello all,
i hope this is in the correct section.
i have bought a diversity tuner for my car - it cam with a little magnetic base aerial which works ok - as its a diversity tuner it has connections for 3 other aerials.
i am going to make the other 3 as the one that came with it is just a length of wire, what i would like to know is do i connect both ends of the coax to it or just the centre core?
thanks in advance ,
Dan.
simontdc
PostPosted: Tue Mar 18, 2008 8:24 am    Post subject: Reply with quote
You don't say what it's for - FM, TV or what? - I assume it's not GPS as it won't work without a special GPS receiver. As GPS makes range measurements from the satellites, having antennas in different places would confuse the receiver, stopping it using the satellites altogether.
G1NTX AFRIN LRPS
philpugh
PostPosted: Tue Mar 18, 2008 2:28 pm    Post subject: Re: help please making a diversity aerial Reply with quote
You should connect the central conductor and the outer sheath at both ends in order to reduce interference.
Phil
dany_boy
PostPosted: Wed Mar 19, 2008 2:49 am    Post subject: Reply with quote
sorry i forgot to mention its a 'universal diversity tv tuner', i thought diversity tuners were only for tv Embarassed
thanks philpugh, i'm off to make a couple of antennas!
cheers.
Dan.
philpugh
PostPosted: Wed Mar 19, 2008 10:07 am    Post subject: Reply with quote
You can get diversity units for other frequencies/applications - usually used in cars - to help get the best signal strength. Look at any fully equipped police car - all the similar looking aerials will be connected to a diversity unit - usually.
Phil
Skippy
PostPosted: Wed Mar 19, 2008 7:29 pm    Post subject: Reply with quote
And in 802.11 WiFi - that's why you see these wireless access points with two aerials......
Gone fishing!
22.054 (22 May 24)
