Pocket GPS World :: View topic - nokia n95 & external bluetooth GPS connection
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
morph
PostPosted: Thu Aug 09, 2007 9:44 am    Post subject: nokia n95 & external bluetooth GPS connection Reply with quote
does anybody know how to connect the nokia n95 to an external bluetooth gps?
ive paired the devices successfully but don't seem to actually connect and use the GPS in map mode. it seems to always use its own internal GPS which isnt as sensitive as my external device.
any help much appreciated! Laughing
ipaq 4150, otterbox 1900
copilot 5 live memary map
brodit passive holder
rikaline bluetooth gps
Tim Buxton
PostPosted: Thu Aug 09, 2007 5:08 pm    Post subject: Reply with quote
I'm not sure if you can use an external GPS with the Nokia maps. I have TomTom and Garmin applications on my N95 and they can both use external GPS (the Garmin is tied to a Garmin GPS) but not the internal one.
Tim
morph
PostPosted: Thu Aug 09, 2007 9:52 pm    Post subject: Reply with quote
doh,
that would explain it Confused
ill be putting viewranger on soon, so ill try again then.
thanks
linked up external GPS (found the right menu) works nicely with the nokia map software
enanjay
PostPosted: Mon Aug 13, 2007 11:08 pm    Post subject: n95 gps Reply with quote
If you look at the programme "GPS Data on your phone assuming it came bundled with the phone, then on the first screen with navigation, position and trip distance on it select options then positioning settings and then select bluetooth gps and then enable, it should then find your external gps then when you run nokia maps it will ask you if you want to connect via blue tooth
morph
PostPosted: Tue Aug 14, 2007 10:22 pm    Post subject: Reply with quote
yep found it a few days ago... and it works
cheers Very Happy
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
22.062 (12 Jun 24)
