carcuscrae Occasional Visitor
Posted: Wed Jul 18, 2007 3:56 pm Post subject: TT 720 & TT 910 |
Ok, I have a TT 910 but I do like the look of the new TT 720's therefore I am thinking of getting one. As I like to have the maps from the US from the 910, is there anyway I could get an SD card and load them on there and use on the new 720?
Thanks |
Andy_P Pocket GPS Moderator
Posted: Wed Jul 18, 2007 4:59 pm Post subject: |
Same question as HERE really, although with the extra step of copying from your 910's harddrive.
I assume you still get a product code number for the map when you buy a 910? |
Posted: Wed Jul 18, 2007 5:53 pm Post subject: |
Thanks for the reply.
Yes I still have the product code so I assume I can then just copy it using TT home? Or do I have to do something else to get it off the HD?
Thanks |
Posted: Thu Jul 19, 2007 1:16 am Post subject: |
I hope you've already got a backup on your PC! - So you should be able to simply copy and paste it from there to the new unit (SD card or internal memory if it's big enough.
If you haven't done a backup, PLEASE do one straight away before you even think of doing anything else.
Don't use Home, it has a tendency to miss bits out of it's backups, use the instructions HERE |
Posted: Thu Jul 19, 2007 9:37 am Post subject: |
Thanks for your help with the backup instructions. I do already have backups but I wasn't aware of the problems with TT Home.
Now I have my full backup do I just have to copy the US maps to the SD Card or are there other files required as well?
Thanks |
Posted: Thu Jul 19, 2007 1:10 pm Post subject: |
Can't say for certain, as the 720 isn't officially released yet, so very few people have seen one...
On the "ONE" new edition with the 1GB internal memory, it uses EITHER the memory OR the SD card, so if you put a map on a card you also have to add all the system files. (Daft!).
However, PGPSW have had a preview of the 720 and I read on here that TomTom have sorted it out so the 520/720 can use both the memory and the SD card simultaneously, so you would only need the map itself.. |
thebinman Banned
![](https://www.pocketgpsworld.com/images/banned_user.jpg)
Posted: Thu Jul 19, 2007 1:54 pm Post subject: |
Andy_P2002 wrote: | TomTom have sorted it out so the 520/720 can use both the memory and the SD card simultaneously, so you would only need the map itself.. |
Really? I find that hard to believe but I suppose I may be proved wrong (one day) ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Posted: Sat Jul 21, 2007 12:58 am Post subject: |
Told to us on this forum by one of the PGPSW team who has an early review model. Too tired to search out the quote tonight! |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Sat Jul 21, 2007 7:27 am Post subject: |
It was I and I can confirm that the model I have (sample, not review) can use both internal and external memory simultaneously. However, as this is a sample and not a production unit, this might change. Let's hope not. _________________ Tim |
FazerUK Lifetime Member
![](modules/Forums/images/avatars/19986321594676bd60aa311.jpg)
Joined: Nov 18, 2004 Posts: 242 Location: Wrexhaml, UK
Posted: Sat Jul 21, 2007 4:24 pm Post subject: |
TomTom would not let you have two active maps on two device as far I am aware _________________ TomTom Go 700,
with External Antenna, External Mike
App v7.160, OS:2324, GPS v1.21, Boot 5.4201
Western_Europe-Map v650.1127 |
Posted: Sat Jul 21, 2007 5:44 pm Post subject: |
You can have as many activated maps on the device as you want, but only one map will be set as active (the one currently in use, switching between activated maps is easy - Change Preferences/ Manage Maps/ Switch Map) - Mike |
Posted: Sat Jul 21, 2007 6:30 pm Post subject: |
FazerUK wrote: | TomTom would not let you have two active maps on two device as far I am aware |
How do you mean? _________________ Tim |
Posted: Sat Jul 21, 2007 7:42 pm Post subject: |
Tim Buxton wrote: | FazerUK wrote: | TomTom would not let you have two active maps on two device as far I am aware |
How do you mean? |
If hes talking of moving his maps from the 910 and putting them on the 720 when he guys it. _________________ TomTom Go 700,
