Pocket GPS World :: View topic - Navigate to Favourite - route not found
PaulBt
PostPosted: Fri Jul 06, 2007 3:36 pm    Post subject: Navigate to Favourite - route not found Reply with quote
I wanted to add a hotel into a TT910, that I knew I would only use a few times over one weekend, so when parked (in the carpark) I simply added the GPS position as a favourite, rather than selecting a POI catagory for it.
The trouble came when cold wet and tired, we wanted to get back to the hotel, and TT said "no route found" 8O
Lots of mucking around then ensued. Rolling Eyes
The outcome of which was if I had set the location as a POI TT would have found a route to the nearest point on a road, but as a favourite with no road there it said there was no route available.
Is this normal Question
Paul
TT720 V8.010, regular audio book user.
WestEuro v805 connected to E90 on O2
TT910 V6.525, TTN5, TTN3, TT on Psion 5mx
46jimbo
PostPosted: Fri Jul 06, 2007 3:51 pm    Post subject: Reply with quote
When setting a favourite, it's best to do it close to the road at the entrance to the parking lot. Going away from the road just confusing the TT.
However, I didn't realize that it worked differently if it was set as a POI rather than a Favourite.
PostPosted: Fri Jul 06, 2007 4:19 pm    Post subject: Reply with quote
Paul, have a read of This Thread from last year which I think is the same problem, for some strange reason storing off road locations is possible and you can navigate to them, but you have to enter them from the browse map options for the location to be used for subsequent navigation - Mike
PaulBt
PostPosted: Fri Jul 06, 2007 4:41 pm    Post subject: Reply with quote
Trying it again here, in the office Wink
I did the following tests:
1. From main menu pg2
add favourite
GPS position Sad
2. From main menu pg1
Change Prefs
prefs pg2
Manage POIs
add poi
(choose a catagory)
In "add as POI pg2" GPS position. :D
3. From main menu pg2
add favourite
Browse Map
select blue arrow ( top right hand corner)
Done. :D :D :D
So solution 2 gives you a POI while solution 3 gives you a favourite.
How strange Confused
Paul
PostPosted: Fri Jul 06, 2007 4:53 pm    Post subject: Reply with quote
I did say the method of entry to get this to work is strange, not sure why there is such inconsistent behaviour but at least you now know how to overcome the issue - Mike
Oldboy
PostPosted: Fri Jul 06, 2007 6:11 pm    Post subject: Reply with quote
From Browse Map you can do both. Add as Favourite or Add as POI.
22.053 (15 May 24)
