Pocket GPS World :: View topic - Mesure programs - Car racing. :)
jlw
PostPosted: Wed May 26, 2004 11:39 am    Post subject: Mesure programs - Car racing. :) Reply with quote
I just downloaded a great program that record data and gives me 0-100 times (0-60 mile/h ??) and lot of other stuff. But the program cant analyse the code and give me the info in the pocket pc. I need the oakgps to anylyse it. I want to know if there any similar program as the one i found WITH a analyser. Smile Would be great to have.
But http://www.ake.nu/oakgps/index_eng.html works just fine. Or have not tryd it yet. But my friends have. Smile
Hope someone can helt me!
regards
lbendlin
PostPosted: Wed May 26, 2004 2:07 pm    Post subject: Reply with quote
We had this topic already a while back. You need to be aware that the standard GPS sampling rate is 1Hz, so you will have a tough time (sic) to measure time in the sub-second range as well as the distance you travel within one second. Obviouly this is especially bad with race machines.
Lutz
TomTom/TeleAtlas NAVTEQ
jlw
PostPosted: Wed May 26, 2004 2:14 pm    Post subject: Reply with quote
yeah, i know. if you look at the page in my page above they have tested fotocells (i think the eng word is?!?) and the gps method. The gps did very well.
jlw
PostPosted: Thu May 27, 2004 1:04 pm    Post subject: Reply with quote
My friend explaind a good method of timing 0-60 and 402 mters and 402 meters etc.
Download this program
ftp://gps:gps@81.228.189.128:8282/GPS/NMEAMon.exe
It's my ftp its not up forever. Smile
And then download
OakGPS calculator:
http://www.ake.nu/oakgps/OakGPS.zip
(noy my server)
And then start the oakcalc via this command line:
"OakCalc -inputfile C:\GPS\Test2.txt -startcorrection -speedtarget 100 -distancetarget 201 -zerolimit 1"
It's a bit tricky.
After that the program have generated a few files. And the program gives you info like this
Acceleration Run 1
Speed: 0-100 km/h in 7.91 seconds at 130.12 meters.
Distance: 0-201 m : 10.23 @ 113.37 km/h.
Pretty cool i think. Smile
pr0ton
PostPosted: Tue Jul 04, 2006 7:17 pm    Post subject: Reply with quote
And then download
OakGPS calculator:
(noy my server)
It's a bit tricky.
Acceleration Run 1
Hi, do you still have that NMEAMon.exe somewhere?? I would like to give it a try Smile
pr0ton
PostPosted: Wed Jun 27, 2007 5:45 pm    Post subject: Reply with quote
Found the software from here http://harukaze.sakura.ne.jp/garmap/download.html
robertn
PostPosted: Wed Jun 27, 2007 9:46 pm    Post subject: Reply with quote
The NMEA comes in at 1 second intervials, most GPS's report a rolling averge anyway. between the two you will get a more accurate 0-60 with a stop watch and a passenger watching you speedo.
Next time you go for a drive, pull an emergency stop from 60 down to 0, and once stopped, see how long you GPS takes to report 0mph.
GPS can provide incredibly accurate timeing figures, as the clock on it is from atomic clocks, but you will need two specialist devices, one at each end, and a sensor to tell it when to start and stop. Not something your average consumer GPS is capable of doing.
22.055 (29 May 24)
