Pocket GPS World :: View topic - Autoroute 2004
Autoroute 2004
gussy
PostPosted: Mon Nov 24, 2003 5:58 pm    Post subject: Autoroute 2004 Reply with quote
Hey peeps
Will the speed cam database work with autoroute 2004??? is it easy to install if it does???
PostPosted: Mon Nov 24, 2003 9:53 pm    Post subject: Reply with quote
Don't know about AR2004, but it works with AR2002/2003. It's on our Q/A's on the Safety Camera Page.
Q. Can AutoRoute use the UK GATSO Database ?
A. Yes, from the November 2003 release (v1.111) you can import the CSV file within the ZIP into AutoRoute using DATA | IMPORT DATA WIZARD | Select the CSV file, then select COMMA Delimited, the first column you should set to Longitude, the second column to Latitude, and the third column to Name. Click Finish and the data should be imported as pushpins into AutoRoute.
PostPosted: Mon Nov 24, 2003 10:13 pm    Post subject: Reply with quote
Yes you can display the camera locations in AR2004 but you won't get any alarms as you approch them if you are using it hooked up to a GPS.
