Pocket GPS World :: View topic - TT Home says that my device is NOT connected...
Agent_Trig
PostPosted: Fri Nov 03, 2006 1:24 pm    Post subject: TT Home says that my device is NOT connected... Reply with quote
Why does my TT Home say that my TT1 V2 is not connected when it clearly is? I can access the data on my TT through Home and copy and delete stuff but when I click on the TT Icon it shows a silhouette of my TT with a message saying "No device found, please check that it is connected and switched on".
Any ideas?
Cheers Wink
Shinymera
PostPosted: Fri Nov 03, 2006 3:50 pm    Post subject: Reply with quote
When you installed TT HOME, did you let it download the latest version from the internet?
It needs a additional component also which it downloads the first time you use it.
Check your version and if need be down load the latest HOME and install it.
Agent_Trig
PostPosted: Fri Nov 03, 2006 5:27 pm    Post subject: Reply with quote
Yeah it did download and install an update the first time I used it and it still doesn't detect my TT.
When I load up Home and check for updates and it says that there are no updates available Confused
princeofpeace
PostPosted: Fri Nov 03, 2006 6:32 pm    Post subject: Reply with quote
I had same problem and reset my TT and it detected - kept doing it every time I connected USB and fed up resetting so contacted TT support - they sent me an 'exec file' to remove a reg entry and ever since - no problems
